| How to make photovoltaic solarpanels to suit our boatdesign Today, it is possible to get all the ingrediemts to make a good photovoltaic solarpanel. Sometimes the shape of the square panels does not suits the design of the boat and by making our own panel, we could get the right dimensions. Most of is need a panel in anyway, for our house, caravan or boat. Provided we are more costeffective then buying a complete panel. One has to bear in mind however that you need a number of cells in serial to get the right voltage at low ambient and higher ambient temperature. Also the regulator need some extra "juice" (voltage). The standard is 18 cells for 6 Volt and 36 Cells for 12 Volt system. I always prefer to put an extra 37th or 19th cell into the system, as then by low light levels or wrong angle of the lightbeam, still something is charging the battery. I am not an expert, but maybe together we can make some cost effective panels by exchanging some crucial details needed to make them. a) we need a reliable supplier for the cells. is this the one??? http://www.quadmodsusa.com/solarcells.html b) we need the best price for the cells. c) we need anodized alluminium or alluminium which is powdercoated. d) we need suppliers of hardened glass on which we can walk. 3,2 mm hardened glass. e) we need to discuss special shapes, like a circle, would that be nice to have it in such a shape. f) the connections, what is the best. g) the layer between baseplate and the very brittle solar cells and the next layer between glass and cells. h) what type of glue should be used. etc. Well shall we go for it to make our own panels?? |
| An interesting supplier. I think they buy and sell overstock items, so we must keep watching their offers. At this moment I saw only polycrystalline cells. Making your own offers new possibilities like following the curvature of a deck area. You could use clear resin instead of glass.
Is there clear resin onthe market, at which UV has no long term effect? Bert |
| You may want to look at the UV protected clear polyurethane resins. You'd probably need to heat cure them though. -jim |
| interresting... perhaps can we use polycarbonate/lexan sheet to protect the cells? lighter and unbrackable? it's any risque of condensation below the glass? or the cell are glued on it with a PU/acrylic resin? cheer's bertho
__________________ creating and building simple boat is much more difficult than complicated ones..... |
But, yes, it is something to look at. |
Now we are considering to poor ????? over the cells and have a special shape. I assume one has a baseplate, thin stainless steel 304 or 316, bent it to the right curve needed for your boat ( not too much) , put a 2 - 4 mm ??? soft layer on it. Place all the solar cells on it, make the electrical connections, poor the resin over it and you have a solar panel according to your likings. Whether you are able to walk on it, is a big question. It depends how much the surface will bend. If too much, the cell will crack and your solarpanel will give a reduced output or open circuit. Bert |
| I have a flexible panel that keeps the boats batteries topped up. Small cells embedded in silicone resin, probably a stainless steel foil as a base, a vinyl envelope sewn at the edge, the top layer is clear vinyl (like the rear window of a cabrio). We sit on it and stand on it and some cells are broken from a pencil or coin under the panel while someone stood on it, but as long as the straps aren't severed, even the broken cells contribute. Of course after 15 years the vinyl doesn't perform as well as glass anymore, but it serves me well. It was blown in the sea at least 10 times without any damage. A Siemens SM-55 panel I used on board for the same purpose once fell off, hit the sea rail and shattered into a million pieces.
The americans are lucky, they order and the next day it gets delivered to their doorsteps at a reasonable cost. Quote:
Thus we agree then, we use a resin. Bert |
| solar option for this design Re: for new design..I would be interested in specifications that can be produced by a solar panel, sizes of panels required, battery requirements etc? |
| Availability issues Bert, I assume ordering solar chips and have them delivered in SA is not your problem. Do you have to pay tax and import duty? The interconnections wire and eutectic tin wire will also be no problem as you can get that from the same source. I found it almost impossible to buy chemicals in the USA because there is a lot of paranoia about liquids and airfreight. Can you buy bedding compound or other elastomers in SA? Silicone in cartridges are suitable only if there is no vinegar smell and the material is allowed to cure uncovered. But a 2-component product is much easier and can be covered with mylar, vinyl or polystyrene immediately.
| yeah, be careful how you word things on custom forms especially pertaining to electronics. I sold some old flashbulbs to a vintage camera collector in the yukon and postal customs held them for 3 weeks before satisfied and forwarding them on. when I inquired as to why I was told flashbulbs can be used as an iginter in a homemade bomb. who'd have thunk it?
__________________ Seeking the uncommon in the common |
Will need some time to get my Windows7 going. I am so fustrated, none of my 3 computers works anymore. I may consider to go back to WindosXP, I have no more e-mail. I have to dial into my service provider to read my messages. So much for the 30 odd updates I have received already on Win7 since Saturday. I am a Unix man, no virusses, no fustrations. |
Bert |
If you charge a Lithium single cell, with a Microchip single cell microprocessor, you need 6,8 Volt , i.e. 13 to 14 cells IN SERIAL. If you like to charge your 12 Lead Acid battery, you need 14,4 Volt to charge the battery and then the overhead of the voltage regulator, which need another 3 Volt at least. Thus you lend up with 36 cells in serial. I always say, make it 37, in case the angle of light inval is not so good anymore. The rule of the thumb is, approx 12 - 14% in practise per 1 square meter of sunlight inval at midday = 1000 watt (if you are lucky ) . i.e. If you have a square meter solar panels, you can expect 120 watt. There are some expensive solutions which may give you 160 watt. We even have information that with an inexpensive reflector, you could increase your output to 20%, but you need also 20% space. Nothing for nothing. But a reflector is cheaper than a 2nd solarpanel. Always use a diode between the panel and your equipment or battery. You can connect solarpanels parallel, provided the no of cells are the same and you use shotkey diodes between panels and center terminal. i.e. you have 10 panels parallel, you use 10 diodes all directing to the center terminal. Preferable a shotkey diode. I use a 10 Ampere diode at $ 0,70. The losses is very low, only 0,15 - 0,2 Volt at 5 Ampere. i.e. you loose 1 watt. You can charge a battery direct from the solar panel, provided the current is low and does not damage your battery. example. You have a 60 Amperehour 12 Volt battery and a 36 cell, 50 milliAmpere solarpanel. It will keep you battery charged and should not do your battery harm. But if your panel is 4 Ampere and 37 cells, you better use a voltage regulator. |
| Am I crazy- Fire Suit ON! | Steve in SoCal | Boat Design | 40 | 05-15-2007 12:26 PM |
| Will you go for PVs (photovoltaic cells) on board? | PVboat | Open Discussion: All Things Boats & Boating | 0 | 11-22-2006 06:19 PM |
| solar (or photovoltaic cells) on boat | PVboat | Electrical Systems | 2 | 06-19-2006 02:52 AM |
| Will you go for solar (photovoltaic cells) on boat? | PVboat | Boat Design | 15 | 06-11-2006 08:53 AM |
| Which program suit me the best | Birol Ernalbant | Software | 5 | 10-14-2002 09:17 PM |
