Old 05-15-2009, 03:49 PM
BTG YACHT DSGN's Avatar
BTG YACHT DSGN BTG YACHT DSGN is offline
-sailing is believing-
Rep: 33 Posts: 100
How To Make Linesplan In Blender 2.48?
Hi
Is it possible to make lines plan (or how to produce them) upon the 3D model in Blender (ie. the hull made in DELFTship to fit naval arch. requirements, but whole superstructeres etc. made as Blender file).
OR
What to do to get printed lines plan (for a baitboat )? ie export it somewhere or make some trick with it?
ANY help welcomed!
regards,
Kuba
Old 05-15-2009, 06:20 PM
kerosene kerosene is offline
Rep: 175 Posts: 420
I doubt the naval architect crew has experience with blender.
I have not used blender but on 3ds max or any regular animation 3d software you can bring back ground images and draw lines on top of that. You can also draw lines in photoshop and export them as adobe illustrator paths. I would assume that blender imports .ai format.
CG- forums such as cgtalk will probably be a better help.
Old 05-16-2009, 04:14 AM
Rep: 33 Posts: 100
Yes, I know that trick with the 'blueprint' in the background, but I was asking for something else, actually:
I have a blender file (with hull & other structures) and I want to export somewhow to make linesplan (hull+structures).
Is there any feaature in Blender that makes cross sections of the model ie. buttocks of whole boat or sth like that?
Old 05-19-2009, 03:21 PM
Bogey Bogey is offline
Ive been using blender for a while.
One way you could try is with the script, "knife tool color".
Position a plane where you want a section, and run the script.
Another way you could try is to use an ortho camera, and alter the clip start distance where you want the section. You can then render the result.
Hope this helps.
blender-in-naval-architecture CGN Software 0 09-29-2008 12:06 PM
"Blender" Rendering LP Software 2 12-08-2006 12:38 AM
Import Linesplan DXF to FREESHIP? internetturk Software 18 10-13-2006 04:22 AM
Flying Dutchman Linesplan quicksail Sailboats 1 03-24-2005 05:59 PM
How to make a name for yourself ! Tim_Hastie Boat Design 28 06-06-2004 12:14 AM
