Old 11-07-2011, 10:34 AM
Steptepha55 Steptepha55 is offline
How to make catamarans to carry heavy weight
I'm a beginner. I have read some catamaran history in wikipedia, so I found somethings that interesting.
some ferry(passenger) uses design of catamaran.
I want to know, how can they carry much weight or how to make catamaran to carry as much as possible weight.
I'm building small catamaran for sailing (about 2.4m length) so I found some problems that my boat can't carry as much weight with my own design, I hope that your answer will impove it.
Old 11-07-2011, 11:18 AM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
Increase displacement.
Old 11-07-2011, 11:48 AM
lewisboats's Avatar
lewisboats lewisboats is online now
Obsessed Member
Rep: 1263 Posts: 1,841
Bigger hulls...wide or deep or long (or a combination thereof). To carry weight they must displace a weight of water equal to the total weight of the boat/ship and its cargo, passengers etc. 1 cubic foot of salt water is 64 lbs and fresh water is 62.4 lbs. 1 cubic meter of salt water is 1025 kilos and fresh water is 1000 kilos. Generally most "designers" tend to set the displacement very early in the design as it is a key ingredient in shaping the boat.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 11-07-2011, 11:57 AM
eyschulman eyschulman is offline
Rep: 72 Posts: 160
The things you have to do to make a cat a pack horse should make you think about why the complications of a cat?
Old 11-07-2011, 12:03 PM
lewisboats's Avatar
Obsessed Member
The things you have to do to make a cat a pack horse....
I like that!
Steve Lewis
Lewisboatworks
Old 11-07-2011, 12:22 PM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
Answered my question too, LOL, make them fat, deep and long, but then they won't be efficient, make them efficient and keep them skinny, shallow and still long....
Old 11-07-2011, 12:29 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Finding a proven design for your requirements will put you farther ahead in the long run.
-Tom
Old 11-07-2011, 12:59 PM
Richard Woods's Avatar
Richard Woods Richard Woods is offline
Woods Designs
Rep: 976 Posts: 691
The only sailing beach cats under about 12ft long are beach toys. Because, as you have discovered, smaller catamarans cannot take the weight of even one crew and still sail in a satisfactory manner
The Livingston yacht tender is an 8ft catamaran powerboat but I doubt if it would sail well
I believe Sea Eagle, amongst others, make a small inflatable sailing catamaran. Only for use on lakes though or in very gentle conditions
www.sailingcatamarans.com
Old 11-09-2011, 08:04 AM
Rep: 136 Posts: 421
Might check "Jack's Plastic Welding" for inflatable tubes, rafts and cats. One called the Big Daddy. They also have frames. They can go beyound the local lake, how far might be based on nerves and skills.
While I have never seen one, they can add different shapes welding them to a basic tube to form flat or curved areas that might make them more than just a O pontoon. But I'm sure most all you guys knew that....
Old 11-09-2011, 09:02 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
The scaling factor is of great importance in all boat design but nowhere is it as important as in a performance catamaran. Displacement varies as the cube of the size ratio of two same design hulls. Increase the size of your 2.4 M (8') by 26%, which is 3 M (10'), and its total displacement doubles. That is how you control carrying capacity and how the big cats can haul 700 or more people and their cars.
Once you decide what the boat is intended to do, the first design step is to calculate the displacement required to do that. Only then can you look at the other factors. It seems the natural thing for most beginners go at this backwards. Not a real problem as long as you learn how it really works. Everyone wants to design a boat and that is the most fun part of the addiction that affects us. There is a large learning curve though and that will take time and effort, which is also fun as the secrets become visible.
Tom Lathrop
Old 11-09-2011, 10:24 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
as said above go big keeping the cat's lines
Old 11-09-2011, 12:21 PM
Rep: 136 Posts: 421
Yipster, I guess you mean blow up the plans proportionately.
A rough cat sold on Ebay not long ago that was a motor cat, it appeared to have about 4' deep hulls @ maybe 30", bet there was little rocker, about 20' long with a simple deck and a small outbaord. IMO, rather crude looking, barge like, but it sold and guess it worked. So I guess two long boxes with pointed ends will work for some. I bet a car could have been floated on the thing, but not my car!
While I could build something similar in my garage without plans, I wouldn't. Even though it would work, it wouldn't work as well as a professionally designed boat for sure and if I'm putting any real money in it, I'd get a design.
Old 11-10-2011, 09:17 AM
yipster's Avatar
may i agree on that and thank you for the translation my expressions sometimes need "blow up the plans proportionately" as that was exactly what i meant
have looked at those cheap landingcrafts thinking it would fit a camper but discarded that idea before, can still imagine a sailing big bus / riding boat tho ;-)
ofcourse weight makes displacement grow but block coefficient can remain when upsizing and although weight is important i belive a cat's advantages over a monohull may still be there
if you know what i mean, than again maybe i'm wrong, but that should be not so hard to calculate when needed
Old 05-07-2012, 02:24 AM
Baloo Baloo is offline
Great forum, could someone be able to guide me to get plans for a large barge. Similar to http://www.liquidlounge.co.za/Gallery/LiquidLounge.aspx.
Not interested in the interior finishes, as i will customize this.
Old 05-07-2012, 02:37 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1925 Posts: 3,025
Baloo
What you're looking for, from that link, is what is referred to as a Pontoon Boat. These guys may help you with what you're after. (But there are plenty, just google "pontoon boats"):
http://u-fabboats.com/
Outboards 2009 - HP, Weight, Make Comparison rwatson Outboards 56 02-11-2010 11:49 AM
How to calculate how much weight a hull can carry? thuffam Boat Design 10 12-04-2008 03:06 AM
Catamarans: 2004 Sales Report for New and Used Catamarans catamarans Press Releases 2 08-04-2004 11:24 AM
Catamarans: 2004 Sales Report for New and Used Catamarans catamarans Press Releases 1 06-10-2004 03:53 PM
