Old 09-25-2011, 11:37 PM
Laranjo123's Avatar
Laranjo123 Laranjo123 is offline
Naval Architect/Engr. FG
Rep: 17 Posts: 128
How to get the LOA of the ship?
Hello i just want to ask about how to get the LOA of the ship? Is there any formula existing for this? Is there any percent to where i can use?
Old 09-26-2011, 12:06 AM
FMS FMS is offline
Rep: 125 Posts: 233
Your question is too general to make sense.
Length overall will be defined by the requirements of and limitations imposed upon the boat in question.
Old 09-26-2011, 08:03 AM
Rep: 1493 Posts: 7,447
LOA is the measurement between verticals of the whole ship including appendages, etc. You don't use a formula but a measuring tape or other device.
Old 09-26-2011, 10:04 AM
Rep: 1758 Posts: 1,561
Gonzo is absolutely correct here, LOA is independent of all other parameters.
Now, if you are concerned with Length on WaterLine (LWL), there are some rules of thumb if you know the ship type and tonnage.
Old 09-27-2011, 07:10 PM
Laranjo123's Avatar
Rep: 17 Posts: 128
My prof said there was no ruling for LOA it depends on the NAVAL, it depends on his design? is that true?
Old 09-28-2011, 06:20 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
No matter what the design or who designed it, the terminology holds true..
LOA is total length of boat including any fixture/attachment projecting beyond hull itself.
LWL is length of boat at the waterline at rest or moving, variable with load/hull type/speed etc.
Beam is width of hull.
See sketch:
Hoyt
Old 09-28-2011, 09:55 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Depends on the constraints and objectives for the design, and how the design was generated.
For example, if a vessel will need to go through locks then it's LOA has to be short enough to fit into the lock.
If there are no constraints on LOA and the designer starts with a set design LWL, then LOA will be the result of various decisions made during the design process.
Old 09-28-2011, 10:32 AM
Absolutely true.
Laranjo123, often the naval architect is given a "design box" which he cannot excede. This may include maximum LOA, maximum Beam, maximum Draft, maximum Air Draft, maximum Tonnage, etc., and any combination of these.
So a designer who is given the task to make a 7,000 TEU container ship may be limited by a maximum terminal crane reach of 110 feet, which sets the beam. For arrangement and powering reasons he wants a LWL to Beam of ~10 for a LWL of 1100 feet and a LOA of ~ 1155 ft. If he then gets a operational limit, such as a requirement to transit the Panama canal, he may have reduce LWL because of the 1,000 ' LOL limit of the locks and increase Draft to make up for the lost tonnage.
LOA often depends on the design brief, not any particular relationship between hull dimensions.
Old 09-28-2011, 10:26 PM
Laranjo123's Avatar
Rep: 17 Posts: 128
What I did was LOA/LBP=loa/lbp big letters are for parentship and small letters for models. like 46/41 = LOA/ 40 is this correct i'm just using my parentship's length ratios?..
BTW thank you for sharing your exp. I really appreciate your helps. hehe
Old 10-03-2011, 09:55 PM
The first formula doesn't correspond to the second. Please be consistent.
Old 10-03-2011, 11:19 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
it may not include spars
http://en.wikipedia.org/wiki/Length_overall
Old 10-03-2011, 11:40 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
The plot thickens.
LOA according to Gonzo means the total length of a boat and you simply measure it.
Peter Radcliffe points us to a Wikki page that confirms this.
Where are all these formulas coming from?
One confused Poida
Old 10-04-2011, 12:39 AM
philSweet's Avatar
philSweet philSweet is offline
Rep: 658 Posts: 621
Defining this term accurately is not to anyone's advantage. As long as the def. is murky, it is negotiable. Please cease and desist.
Bolger Light Schooner (23.5' LOA) kdhorton Sailboats 0 08-17-2010 03:04 PM
A New, Bigger, Skiff/Trimaran at 18' LOA Chris Ostlind Multihulls 0 03-03-2009 07:44 PM
33ft/10m LOA motorsailers. Why there are so few of them? xarax Motorsailers 30 12-22-2006 07:40 PM
DLR (slenderness) and LOA/LWL ratio samh Boat Design 3 08-18-2004 08:20 PM
Trimaran design help needed 40' LOA eightwgt Services & Employment 6 05-16-2004 12:14 PM
