Old 07-23-2009, 01:18 AM
zalads zalads is offline
Rep: 10 Posts: 2
How to Find CG, MI, Ztop and Zbottom of the I section shown below?
Please explaing me how to find CG, MI, Ztop and Zbottom of the I section shown as attached here with.
How to Find CG, MI, Ztop and Zbottom of the  I section shown below?-i-section.jpg
Old 07-23-2009, 03:25 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1925 Posts: 3,025
Have you begun to study basic structures yet?
Old 07-23-2009, 04:37 AM
Rep: 10 Posts: 2
Yes, just started my studies can u pls advise me how to do this
Old 07-23-2009, 05:17 AM
Naval Architect
Well first, you need to start a table with seven columns with these headings:
item, area (a), lever (h), ah, ah^2, k^2, ak^2
Then find the area, the lever of each item about a fix datum. Then calculate the 2nd moment of area for each item and finally its own inertia about its own axis. Add up the columns and by parallel axis theorem move the axis from assumed datum to the neutral axis.
If this does not make sense, then you require much more reading before advising further.
Old 07-24-2009, 06:56 AM
Greybarn Greybarn is offline
Rep: 10 Posts: 57
This is a second year of college level engineering problem. What year are you in your studies?
Old 07-25-2009, 12:15 PM
Rep: 1493 Posts: 7,447
Is the material homogenous?
Old 07-25-2009, 04:10 PM
Yellowjacket Yellowjacket is offline
Rep: 292 Posts: 249
You need to use the parallel axis theorem...
Here is a link..
http://en.wikipedia.org/wiki/Parallel_axis_theorem
Classy Hydrofoil - Has this been shown here before! Guest625101138 Boat Design 1 05-09-2008 09:15 AM
section modulus lyqqmxm Class Societies 8 02-03-2008 05:54 PM
GL: The section modulus VVC3k Class Societies 0 01-22-2008 03:11 AM
Section locations Willallison Software 1 07-21-2003 12:07 AM
Press Release: CADCAM and Cargo Management software shown at Nor-shipping, 3-6 June boatdesignnet Press Releases 0 06-06-2003 03:33 AM
