Old 05-12-2005, 02:54 PM
brendodendo
how to fiberglass and varithane wood?
This might sound silly, but in which order would I work? Do I lay the fiberglass on the wood and then varithane over the top, or should I varithane the wood first and and then lay fiberglass. I'm really confused. e-mail to bapetersen@yahoo.com.
Thanks alot
bp
Old 05-12-2005, 04:23 PM
Ssor Ssor is offline
Rep: 10 Posts: 174
BP, Varithane is a polyurethane type varnish. It is unusual to bed fiberglass in varnish. I have done it but not for anything that was expected to last very long.
If I may, I suspect that your question really was do I lay the fiberglass cloth and then apply the resin or do I wet the wood and then lay the cloth in the wet resin? And that answer is you can do it either way, it is a little easier to get the cloth to lay smoothly if you apply it to a dry surface but a bit more difficult to be certain that the wood is well wetted. If you have a helper then wetting the wood and laying the cloth would be my choice.
Old 05-12-2005, 08:32 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Laying glass overtop of varnish is an open invitation for delamination. Varnish and fibreglass really don't get along too well. If you want the wood look, there are clear resins you can use with the fibreglass to do this. If you want glass, paint a coat of resin on the wood (it will soak in a bit), lay the cloth, wet it out. If you want varnish, follow the manufacturer's directions. Using varnish and glass together will not work very well; it will certainly have almost no strength.
