Old 01-13-2010, 08:21 AM
mystrwizard mystrwizard is offline
Rep: 10 Posts: 5
How to fair hull lofting (2D) on paper?
Ive got some station offsets for an Outrigger and have been drawing the stations using Autocad and noticed some of the offsets are not on the same lines if I draw a spline to connect. I can adjust those points to coincide to the spline so the offsets are fair but then Im not sure if Ive messed up the fairing of the waterlines.
Is there a drawing technique (2D) for lofting plans where you can fair the station lines and the waterlines together on paper. Then Ill take those new offsets and start cutting out my stations for strip planking.
Thanks for all the help!
Reese
Old 01-13-2010, 08:31 AM
Rep: 1758 Posts: 1,561
Autocad will not fair a shape correctly. This is based upon trying to do that since Acad 2 back in the late '80s. It will get close, but never on.
As far as traditional lofting goes, yes has been done by hand for centuries. Use a spline (batten), ducks (spline weights), and a good eye. There are several books, or chapters in books, on lofting.
Remember, in todays world, don't get down on your knees before the computer and examine with a microscope the 5th decimal place of a virtial line on the screen. Stand on your feet like a man and stand back while you ponder the fairness of of the curve you just drew.
Old 01-13-2010, 12:55 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 158
Originally Posted by jehardiman View Post
Snip Remember, in todays world, don't get down on your knees before the computer and examine with a microscope the 5th decimal place of a virtial line on the screen. Stand on your feet like a man and stand back while you ponder the fairness of of the curve you just drew, then get down on your knees and loft it full size.
There, fixed it for you
Old 01-14-2010, 09:28 AM
I thought that is what apprentices are for....
(Been there, done that, got the scars on the knees from kneeling on a batten nail....)
Lofting CD set- Lofting with Arno Day longfellow Marketplace 0 04-24-2009 09:51 AM
What's the best way to fair 1708?? mongo75 Fiberglass and Composite Boat Building 22 09-12-2008 10:23 AM
Heavily oxidised hull, what grit paper before painting? GWB Fiberglass and Composite Boat Building 1 04-02-2008 03:40 PM
Hull lofting software emmegi Boat Design 1 09-21-2004 05:19 AM
Lofting from a half hull model Guest Boatbuilding 1 11-22-2003 12:12 PM
