Old 07-18-2008, 05:05 PM
Mayor Bob Mayor Bob is offline
How do you calculate the wet surface of a boat?
I am looking at getting my boat hull powdercoated with anti-fouling. The company says that it will do this for x$ per square foot.
The question is: Are there any formulas that will tell me how to calculate the square footage of my inwater hull area? I understand that this area would be different for a flatbottom john boat vs. a deep draft trawler or sailboat. Any suggestions?
Thanks
Bob
Old 07-18-2008, 10:59 PM
Rep: 3125 Posts: 9,398
Multiply the length (in feet) by the beam (width), then multiply the result by .8, which will get you close enough for bids. If your boat is particularly fine in the bow, then use .7 as the last multiplier.
Old 07-24-2008, 04:14 AM
diwebb diwebb is offline
Rep: 65 Posts: 120
PAR has given a good approximation but if you want a more accurate measure it will need a lines plan or you can measure the boat when she is next out of the water. From the lines plan measure each station from the waterline to the center of the boat around the skin of the hull. Then for the area between each pair of stations add the lengths measured for the two stations and multiply by the station spacing. Add all of these areas together and then add the area of the rudder(s) and keel or skeg (dont forget both sides), also add any submerged transom area. This should give you a pretty accurate measure of the ares. If measuring the hull follow the same procedure but set up your own stations and measure in the same way.
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
How do I calculate the weight limit of a pontoon boat? Newboatman Boat Design 6 07-15-2007 08:40 PM
software to calculate CG gonzo Software 6 05-17-2007 04:06 AM
Need to calculate the draft of a boat tibett Boat Design 1 11-09-2004 04:07 AM
My Boat is wet!! Willallison Powerboats 3 02-04-2004 04:31 PM
