Old 05-24-2010, 09:21 PM
Hafiz Zainal Hafiz Zainal is offline
How to do strength assessment
Hye,
I am a marine technology student. I am now building a foldable boat. I have problems to calculate the hull strength since i considering polyethylene as the hull material. Does anyone here know which rule to refer to?
I have go through some rule like Lloyds and BV but I couldn't find the calculation for PE. Thank you.
Hafiz Zainal
Marine Technology student, UTM Malaysia.
Old 05-26-2010, 11:09 AM
Rep: 1493 Posts: 7,447
Are you asking about strength or stiffness? Also, strength is a very loose term. In usuall conversation it may mean many things. If you are planning on being an engineer or technician, work hard at using the proper and specific terms.
Old 05-26-2010, 11:47 AM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
A small foldable boat will not be covered by the classification societies. You have to use first principles engineering seasoned with a bit of street smarts (common sense).
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 05-28-2010, 12:21 AM
petlily petlily is offline
Rep: 10 Posts: 29
As your boat might be a plain hull without any stiffener, it's quite easy just to apply first principles approach. First, find the mechanical properties of PE. Then you should have the section modulus given that you've already figured out the midship section. Assuming your body weight as the projected load, get the overall still water bending moment (shear force is less significant in this case, assuming you have only one compartment). You should be able to find the stress then. Good luck for your 'bot kotak'..and the racing.
damage assessment to boat I plan to buy JeroenW Fiberglass and Composite Boat Building 3 07-26-2008 05:30 AM
Block Strength Cleetus Sailboats 2 09-20-2007 12:09 AM
Transom Strength sunkShips Fiberglass and Composite Boat Building 6 05-15-2007 01:47 PM
Hull Strength Poida Wooden Boat Building and Restoration 2 04-15-2007 11:38 PM
Hydrostatic assessment packages for long keel vessels Sotondesign Stability 2 10-19-2006 06:13 PM
