| How do I 'read' the "Standard Draft Polars" chart http://www.santacruzyachts.com/image...ebBrochure.pdf graph is toward the end of the PDF. Any good tutorial explanations of what his info means to someone who knows about sailing? PS-I can't help noticing I can't see any pics of the hull under the waterline, yet the boat is said to be trailerable. |
| The lines represent the locus of the boat's velocity vector as it goes through the various headings. Notice each line has a number, this is the line for that number windspeed in knots ( at ten meters altitude according to them ) The polar has different circles representing boatspeed. The center represents speed = zero. The further away from the center, the faster, it is marked in increments. The heading is the angle from the wind, straight up is straight upwind. Notice none of the lines reach the straight up axis since the sailboat cannot sail straight upwind. Notice the lines are not continuous. They get to a certain angle off the wind and stop. Then another line starting from about a reach but with the same windspeed number carries on and goes all the way down to the axis that goes straight down, dead downwind. This represents different sail combinations (spinnaker or no spinnaker, etc.). Standard draft just means the polar is plotted for the better performing model, the one with the standard draft. The option with a shorter keel will have a slightly slower plot Hope that explains it for you. My question would be are these real, tested, actual sailing speeds plotted or are they just what a velocity prediction program computer software predicted. You can be sure that if they are the latter (and they probably are), they are going to be somewhat optimistic over real world figures where there are real waves and real control issues. |
| CMD "project Zeus" VS VOLVO "IPS" | gerard baladi | Pod Drives | 13 | 09-10-2007 10:23 PM |
| Boat "workshop" including a "testing tank" | zmfmd | Open Discussion: All Things Boats & Boating | 0 | 08-08-2007 05:43 AM |
| Changing weight of "standard" person | Thunderhead19 | Boat Design | 8 | 04-12-2005 08:54 PM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 03:03 PM |
| Anyone Read "Pilots" by John Cunliffe? | Matthew | Education | 0 | 11-27-2002 11:22 AM |
