Old 01-05-2012, 07:21 PM
Amar Amran Amar Amran is offline
Rep: 10 Posts: 4
how to design the spud barge
can someone show me how to design the barge with the spud..I'm stuck with the spud arrangement for the barge..
Old 01-05-2012, 08:45 PM
Rep: 3125 Posts: 9,398
Are these the mobile spud or fixed spud launchers?
Old 01-05-2012, 09:16 PM
Rep: 10 Posts: 4
it is the spud for the 250 ft ocean going barge..the barge is used for the pipe lay repair..how to arrange the spud on the barge..if the are any method to calculate or example i can use to do that?
Old 01-05-2012, 09:23 PM
lewisboats's Avatar
lewisboats lewisboats is online now
Obsessed Member
Rep: 1263 Posts: 1,841
"Spud" is something most of us aren't familiar with in the way you are using it. To most folks around here a "Spud" is a slang term for a Potato...(Hence PAR's question about launchers...as in Potato guns and other launchers for on the water fun games/wars between small boats)
Please describe what you are calling a "Spud". What is its function? What does it generally consist of? What is it normally constructed of? Where does it go on the barge?
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 01-05-2012, 09:49 PM
Rep: 10 Posts: 4
sorry for not explain more about it..the spud i refer is like in this picture..it is used for stabilize the barge..it's like jack up barge..
Old 01-05-2012, 11:15 PM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1004 Posts: 584
Here's a definition for Spud Barge
A spud barge is a form of barge which can be moored through the use of through-deck pilings, known as spuds. Spuds may be fabricated, or made of commercially available pipe sections or logs. Spud barges are commonly used as work platforms, i.e., for crane or demolitions work, in littoral waters (such as rivers or for canal maintenance/expansion).
So spuds are the piles in Amar's pic that go through or alongside the hull to the bottom to moore and stabilize the barge.
Cheers,
Angel
Old 01-05-2012, 11:19 PM
BPL BPL is offline
Rep: 115 Posts: 154
Right. A spud = a piling. I've heard that before.
I've also seen people write pile or spile instead of piling - don't know if they were bad at texting or it's the lingo somewhere.
Old 01-05-2012, 11:33 PM
Angélique's Avatar
'Spud' in Dutch is 'Sputh' . . . . (the link is a Dutch PDF, but it has pics of the design on page 2)
Good luck !
Angel
Old 01-05-2012, 11:57 PM
Angélique's Avatar
Dutch link ---> Google translation in English or Malay or to set above in what ever language you like . . . .
Cheers,
Angel
Old 01-06-2012, 12:38 AM
Rep: 10 Posts: 4
thank you for all your help..it help me to do the design
Old 01-06-2012, 06:38 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Most spud barges I've seen the spud doesn't go through the deck but rather is attached to the outside of the gunwale with a cable mechanism. The spud (movable piling) moves up and down through a ring or bracket attached to the barge on a cable. The cable is attached to the bottom of the spud and goes through a pulley at the deck of the barge to a winch. When the cable is winched in the spud is lifted clear of the bottom and the barge is free to move. When the cable is let out the spud lowers and buries itself in the bottom acting as an anchor. Because the spud and barge are not rigidly connected to eachother the barge can move up and down on the spud with the tides.
There have been a couple of incidents in the gulf where the spud was not properly secured and dropped unexpectedly, rupturing undersea pipelines. The odds on that seem incredible, but it's happened a couple of times I'm aware of.
Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR
Old 01-06-2012, 06:52 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
I've seen the same as Cthippo and would suggest another mechanism, which is used on a lift barge (with spuds) that I really like:
The lift spuds also are in "rings" welded outside the deck (not through the deck) and have huge linear teeth on them running the length. There is a hydraulic lift mechanism that turns cogs that move the spuds in either direction, lifting the barge many feet in the air.
"You can't solve all of life's problems with epoxy" - My Wife
Old 01-06-2012, 06:58 PM
Angélique's Avatar
Murphy's law . . . . .
Cheers,
Angel
Old 01-07-2012, 12:06 AM
Yobarnacle's Avatar
Yobarnacle Yobarnacle is offline
Rep: 546 Posts: 516
The picture showing a crane barge with 2 spuds on one end is for construction, not pipe laying.
Better to put spud wells at all 4 corners, and in use, one spud aft and one spud forward, both on same side. Better longitudinal stability.
Pipe laying barge normally has a pipe carrying material barge alongside spudded side, stacked with pipe. Pipe is swung into position on deck, chamfered and welded to existing pipe. then lay barge shifted ahead. There is a big rubber tired brake with rollers that maintains tension on pipeline, so weight of pipeline doesn't drag if off of barge. Shiftimg is normally done with 9 anchors. Spread of 2 from each corner, and 1 more abeam amidship on up current or windward side.
Spuds need be sufficiently strong to hold not only lay barge, but pipe laden material barge, and the tug landing and taking material barges away.
quoting Mr Efficiency,
"Live long enough and you will find yourself living in a "foreign" country!
"The past is a foreign country: they do things differently there"
Barge with Spud internetturk Stability 3 03-17-2011 11:02 AM
Hydrolic System for Spud internetturk OnBoard Electronics & Controls 2 08-30-2009 03:39 PM
Exterior spud system for lcm8 landing craft bucanero Boat Design 2 09-12-2004 06:30 PM
Barge Design K Spears Boat Design 4 01-26-2004 10:39 PM
barge design Boat Design 0 02-09-2002 11:23 AM
