| how to decide a hull form MAy i know what will be the construction cost for flat tob barge and for round hull of 100m x30 mx6m. |
| You should ask someone locally. Labor and materials are so different in different loactions that only local folks can give you a reasonable answer. |
| thanks for your replay,,, may i know rougly if both flat top barge and round hull are using same type of material... how many % the cost will be more for round type hull construction ,as well steel cost...(consider iam using normal steel.) |
| I see you're in India. the cost in Inida will be different to Europe, will be different to US will be different to Asia...so best ask your local shipyard if you don't already work for one. |
| Thnaks...Ad Hoc, I will be tryng to find sombody whos working in shipyard... |
| how to make lines for new design Hello, May iknow how to develope lines for a ship. Here iam starting a design from scratch , I had calculated the intial dimensiones,,,. Is there any chart or any table to develope the offset table,,, or is it just an art work,, of drawing smooth lines and and making the offset table from that. ![]() |
| Hull Form Tools | ParamarineV6 | Software | 7 | 10-13-2009 05:20 AM |
| Hull form modification | Anilkumar | Boat Design | 3 | 04-16-2009 08:25 PM |
| IMS hull form | Mario | Sailboats | 1 | 08-26-2004 04:00 AM |
| Hull Form | Hamidi | Boat Design | 0 | 08-11-2004 09:26 PM |
| Hull form selection | Donald | Boat Design | 13 | 03-16-2004 05:56 AM |
