| How is deadrise measured? Hello all, Please excuse my ignorance here, but how and where is the deadrise of a boat measured. Whilst I hear the term used frquently, I have never really understood what it means. Thank you, - Mr Bean |
| The deadrise is the angle of the V on a hull, and is measured from one half of the hull's rise from keel to chine against the horizontal. (19 degrees deadrise= 19 degree angle up from horizontal) When someone mentions a boat's deadrise, they're usually talking about the angle at the transom, though deadrise can refer to the angle at any point along the hull. Most folks refer to the deadrise at the bow as the "entry".
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| It depends... Hello... A lot of guys measure deadrise as the angle anywhere along the hull that roughly matches the flat of the hull from its main chine against a vertical thru its station lines... Deadrise is the above - angle against the vertical thru stations - taken anywhere and in case of high speed power boats it is measured at what is some times called the ride plane or pad - the aft stations where a properly trimmed boat rides at speed... SH. |
| Heavy sailboats : Can they point ? | xarax | Sailboats | 100 | 06-24-2005 10:36 PM |
| 30 degrees deadrise ? Why not ? | xarax | Boat Design | 13 | 05-22-2005 07:53 PM |
| Help with deadrise & co. | nemo | Powerboats | 2 | 04-22-2005 03:25 AM |
| Variable Deadrise or Modified V? | Paul Dean | Boat Design | 1 | 01-05-2005 07:09 PM |
| Warped plane vs constant deadrise | Willallison | Boat Design | 56 | 12-11-2004 11:14 AM |
