| How to cut wire rope ? Hi, I need to cut a few sections of wire rope which is 10mm in diametre. I could rush out and spend money on a giant cable cutter but for a one off job was wondering if a hacksaw with a fine blade will do ? Or will this take to long ? |
| A QUALITY fine hacksaw blade will do just great, BUT! You must wrap the wire with tape first and cut thru the tape to keep it neat. A vice also helps the cut quality, necessary for Norseman or other similar terminal ends. FF |
| Having been it the situation of cutting metal lines with out a proper cutter before, I can say that a cut off disk and a Dremal-type tool will also work well. Like Fred said, wrap the line with something first!
__________________ Cameron D. M.M. |
| Small angle grinder with a thin cutting disk is used for stainless. Provides a neat cut in cable. |
| Drill a hole in hardwood. Slot the wood to cross the hole. Slip wire through. Use an angle grinder with a thin (1/16") cutting wheel and cut the wire. |
| On trawlers we used a chop saw with an abrasive blade.
__________________ Gonzo |
| To do a nice job with a neat end, braze or silver solder a few inches where you want to cut, cut with a hacksaw, and the brazing will keep the end neat and "hand-friendly" |
![]() I have always used one of these to cut wire rope. Just hit it with a sledge hammer and it cuts clean. |
| Cheers for all the replies. I should have mentioned that I won't have access to electricity. I also don't need a good finish. Seems the hacksaw is the way to go. |
| No ... the best way to cut multistrand wire rope is w a special shear that cuts at an angle while pulling the wire inwards tward your hand that grips the tool. One of the best tools I've ever bought. I don't know what they are called but I used mine first to cut flying wires for ultralight aircraft I may have gotten mine at an aircraft supply store. It's great to have one for electrical wires .. the largest wires go easily into crimp connectors. For me it's a must have tool. Easy Rider |
| I've used a hammer & chisel with a hardened edge on wrapped section of cable. But I don't do this often enough to invest in a special tool. Porta |
| I have used a oxy-acetylene welding torch for bicycle brake wires. I had two metal blocks with a small hole drilled in the seam for the wire. Makes an easy cut and the end will never unravel. Lurvio
__________________ Hopefully creating something useful, since 1983. |
| You can get the type of wire cutter that looks like a bolt cutter with a notch. It takes a bit of effort, but they even work underwater.
__________________ Gonzo Last edited by gonzo : 04-25-2010 at 10:33 AM. Reason: spelling |
| Will not this weaken the wire, heating it, or does it not get hot enought when only soldered/brazed? |
| You wouldn't be able to splice it if it was soldered.
| cnc router cut or cnc plasma cut which one to use | gary1 | Metal Boat Building | 25 | 01-29-2012 05:46 AM |
| How do I control both sheets from one rope? | miniman | Sailboats | 21 | 08-20-2009 09:03 AM |
| Rope tied to a thimble | Fanie | Open Discussion: All Things Boats & Boating | 36 | 07-03-2008 07:22 AM |
| So Many Rope Choices | durwoodghib | Sailboats | 24 | 07-30-2007 03:25 AM |
| rope rub rails | tugman | Materials | 4 | 03-17-2007 07:45 AM |
