| How to create lines drawings from a model? I am an amateur, trying to design a 38ft sailboat. Instead of starting with drawing lines, i wanted to create a scale model. The first step for me was freehand drawings, to get an idea of the finished boat, which i did. Second step was to create a solid scale model (1/14) which is nearing completion. Now i have in my hands a solid block of the boat which is roughly 2.5 ft in total length. Deck and superstructures not yet done or decided. My problem now is how to retrieve the lines from the model to get to the actual lines drawings. I tried to mark and measure a total of 30 points on the hull in x,y,z, and tried to feed them into freeship 2.6 program. The resulting boat is close in appearance but not the one i have. Because unless the points measured are an edge,defining the boundary such as sheerline or keel,all other points become a control point and produce a different curve. They do not become an actual point on the surface of the hull,as measured. I think it is almost impossible to play around with those control points so that the curve goes through the measured point. So i am stuck here. Is there a way to accurately retrieve lines from a model, with or without using software such as freeship? |
| The more measure points you take the closer to the hull you will come. In TouchCad, you can add a series of points into a ruler (line). Then you command TouchCad to reduce the number of control points. The result is excellent! Not sure if freeship has this ability. |
Hello Nero how are you, you home or home? |
"In the years before Naval Architecture had evolved, boat and ship design was developed through model construction. A master builder would fashion a hull form to the requirements of the client. The model would then be cut vertically down the center, leaving two halves.One half would be cut along the horizontal planes, known as waterlines, at evenly spaced distances. The other half would then be cut vertically at evenly spaced distances, known as "stations". These pieces would be laid out and traced in outline on wood or parchment. The dimensions were then expanded to reflect the true size of the vessel, in what is known as the table offsets. This table was used to put the vessel lines down on the lofting floor, from which the construction forms for the centerline structure and framing systems were made. After the process was completed the "waterline" pieces of the model were reassembled and that half was mounted on a wooden backing plate, and often put in the master builder's office to show off the boats that the yard had built." You can find some books on the technique by googling around for 'half models lofting' or similar. Cheers. |
) you still need to draw the stem, the sheer in plan(if you are going to form a big caprail) and you still need to draw the body plan, mast step etc, most buiders do a half model of the boats they build, just to hang on the wall, looks great |
| Down side of doing it the old way is your model is lost. Perhaps, now that he has a good idea of the hull shape he wants, he could create a model with some software? The advantage is he could know displacement. Also, the offsets coming out of the program ( if done correctly) will be fair. Yes, I know that lofting will solve this also. Lazyjack, I am still in Illinois. Getting ready to glass the outside of the first hull. Will dry lay the glass day after tomorrow and wet it out the next day. Looking for volunteers if you want to fly in for the week. (smile) |
best way to make a half model, on cad, make a waterline every 10mm, then put a 10mm a 4 sized piece of ply in your hp desk printer, and so on: ![]() |
| thanks to the coward who posted this An Arrogant **** aren't you. feedback from this thread ) |
| lazeyjack, whats wrong with you man? This is the second time you are doing this to me. We are probably living in different ends of the world. And i dont take my computer to bed with me. Go back to the maltese falcon thread and read my last post. Sorry to all others. And thank you for your comments. Ofcourse i do not want to loose the model by cutting it up. I shall think about how to get it done and give it another try by using freeship. |
| all i said was someone who read thsi gave me bad feedback, not you!! I love turkey and turkish people |
| Well, thats ok then. I didnt understand what you were referring to, but since i posted the original thread, i thought you were calling my name. sorry for the misunderstanding. |
| lazeyjack, i am trying to understand your 10mm waterlines suggestion. what i did before was, six stations between stem and transom, and five lines vertically. top line being the sheer, and the bottom was the keel. additional three lines equally spaced in between,giving me a matrix of 30 measured stations. How is that any different to creating waterlines 10mm apart? Well probably i would end up with many more points, but wouldnt the same problem prevail? ie the curves still not going through the stations. What would happen if you treat all points as an edge? as if the hull has multiple chines, and then try to smooth them out? Would that be possible do you think? |
| With pleasure. Pls let me know when in Ist. |
| Rhino3d- Generate traditional and complete lines drawings? | Robert Miller | Software | 5 | 09-07-2006 06:01 AM |
| Can lines drawings be easily digitized? | Racer/cruiser | Sailboats | 2 | 09-04-2006 04:40 AM |
| 3D Rhino model and 2D drawings | signum | Software | 2 | 08-19-2005 07:35 AM |
| Model Boat drawings | kurmannr | Boat Design | 8 | 08-04-2005 04:28 AM |
| Lines drawings | Huth | Boatbuilding | 2 | 04-06-2002 04:13 AM |
