| how to compare the total resistance. Is there any way to compare toal resistance for round hull and flat barge of 100m length 30m bredth 6 m draft. any formulas..... ![]() |
| Resistance is same based on surface area. Which has less. But notice that shape of hull, Bow has a lot more to do than just surface area. A flat barge has potentially a vertical wall, the round hull more of a bow. Notice that flat barge may sit higher in water than round, therefore may offer less water surface. You need a computer or a be very good with slide ruler. |
Gnerally a rounder hull means less underwater surface area for the same displacement, but some hull forms (like freighters) need stability more than reduced friction You can get any naval architect to produce theoretical figures for you. |
| ".....Is there any way to compare toal resistance for round hull and flat barge.." With more information than just one line question, yes. |
| thanks for you replay.. MAy iknow how to compare the resistanc for ships of same dimension one with round hull and another with flat barge.... Is ther any thumb rule like ...the total resistance for flat barge is some XX% > or < round hull.... |
| There is a good reference on how to calculate the total resistance of a barge that takes into consideration the bow shape and hull surface; Oilfield Publication, Volume 4, "Towing" by Michael Hancox, page 365-366. There are formulas for Frictional resistance, wave resistance and wind resistance (hull & deck cargo) that sum up the total resistance in those pages. |
| Hello Petliy, Thank you very much for your valuable replay.Since I could not find this book nither in net nor in library ,can you pls send me a soft copy for "Oilfield Publication, Volume 4, "Towing" by Michael Hancox," My mail id is :sreenath008@gmail.com |
| I do not have the softcopy nor a scanner with me at the moment. Perhaps, if you google and get lucky enough, you might find a few pages of it. |
| Trying to compare Jeanneau 54DS & Beneteau 57 | zamibc | Boat Design | 56 | 06-24-2009 05:30 PM |
| How does volvo with cone drive compare with mercruiser | loanwizard | Sterndrives | 13 | 03-13-2007 02:29 PM |
| One to compare.... | Sean Herron | Open Discussion: All Things Boats & Boating | 5 | 08-11-2006 10:43 PM |
| Turbulence at the waterline as a fraction of total resistance | JonathanCole | Boat Design | 2 | 05-16-2005 10:16 AM |
| Compare Hp to gearbox to drive | jake | Education | 0 | 03-23-2002 01:34 PM |
