Old 06-12-2001, 04:23 AM
Archive Archive is offline
Rep: 10 Posts: 165
How can I reduce, more force on left site of propeller
As you know, when I design constant pitch propeller which is turning clockwise, I get more lift on the left portion of propeller. I want to design a propeller which has almost equal lift on the left and right side.
How can I find solution about that? I am thinking to put a donut shaped tube around propeller. Is it help to balance bouth side of propeller?
Thank you for your helps
Rep: 10 Posts: 165
If you haven't already read it, I think you would find David Gerr's Propeller Handbook interesting and fairly helpful to get started.
http://boatdesign.net/cgi-bin/bdn/search.pl?query=Gerr
Old 11-08-2002, 12:50 AM
Schoonertack Schoonertack is offline
Rep: 10 Posts: 25
Two things you can try, reduce shaft angle and contraguide your sternpost to equalize your flow to the propeller, desperate measures would be a propeller hub bulb,a beavertail or a nozzel
Old 11-08-2002, 08:39 AM
Tom Lathrop Tom Lathrop is offline
Registered
Rep: 10 Posts: 72
Outside of repealing the Newton's first law, there is probably nothing you can do to the propeller itself that will eliminate the normal and inevitable torque reaction. Redirecting the water thrust coming off the prop will probably do the job but will reduce overall efficiency due to the extra drag created.
Tom Lathrop
Old 11-09-2002, 07:15 AM
yipster's Avatar
yipster yipster is online now
Rep: 1027 Posts: 3,269
hello techno's
are we talking about the same thing?
http://www.boatdesign.net/forum/show...&threadid=1038
counter rotating in line props.....(and shaft!)
yipster
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 01:08 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
Analytical propeller theory Guest Boat Design 8 11-12-2003 02:57 PM
Force Created By Propeller DUCKHTNR Boat Design 4 04-11-2002 12:30 PM
