| Hovercraft dive platform hello, Ive searched the interweb thingy and many sites for info, but couldnt find what I was looking for, I hope someone stumbles upon this and can possibly provide some guidance. Im trying to find guidance about designing a hovercraft, for upto 6 adults, which upon arrival at its destination, could be used as a dive platform. The actual hovercraft isnt much of a problem, but the next bit may possibly be unobtainable. I would like to make the platform as stable as possible, and was thinking of incorporating a SWATHE design into it, utilising inflatable pontoons which are tucked up out of the way during transit, but are lowered when on site. Thankyou for your time, Paul. |
| first thought that came to mind: blowing a swath up under a hoovercraft for stability going in the water is best done than true a hatch in the middle of the craft gee, there is much more to think about... |
| There's already a combination SWATH and hovercraft - it's called a Suface Effect Ship (SES). They have rigid sidewalls like a SWATH, and blow air underneath to support the hull like a hovercraft. See http://www.foils.org/skjold%20brief.pdf for an example of a SES that is of a size that might be appropriate for a dive boat. I think you are a bit confused about your requirements. You say you want maximum stability. But the whole point of a SWATH is to have minimum stability.
| um, I'm not going to get into the discussion of what swaths are intended for against other craft, personally I thought it was primarily for low wave drag... anyway. Moosen, I don't know where you are in the UK, but I suggest you sketch out a few ideas and then go and talk to Gryphon Hovercraft in Southampton. They've been in the game for a large number of years, so they're probably the people to talk to... Personally, I'd suggest a pretty standard hovercraft with tubes that were large enough for it to float with the engine off. There are a lot of interesting question that will creep up in this project. I'll be interested to know what the outcome was, Tim B.
| imagine blowing up only a hoovercrafts sealed skirt and opening major size holes in the legs for wild shallow water shorter wavelengts a smaller platform could work |
| Thanks folks, I think I forgot that people aren't sharing my brain waves, and I dont think I put the problem across well enough. Think I've spent too long thinking about it myself I suppose an easier way of discribing it, is that I would like a hovercraft for the journey, but a platform, that is lifted above the waves on arrival.http://www.nektoncruises.com/Liveaboards/SWATH.aspx is a good example of the "platform" effect I'm after, but a little large the whole "I want a SWATH design" was a bit misleading... but "I want a pontoon thingy on legs that is lifted clear of the waves" confused even me, and I'm supposed to know what I'm after so sorry if I caused any head scratching Cheers for the Griffon info Tim B, I've got a friend making my scribbles presentable, or at least understandable, and I think I'll give them a bell (I'm up North) and see if they have and guidance, always better to be laughed at by folks that do it for a living Thanks again everyone for your time.... |
| a quik second thought i saw and cant find back quik now is a ship that on location goes vertical ( takes a nosedive ) the resulting above waterline stern with 90 degree accomodation makes a small waterplane area for all seastates, not a really wide platform tho ![]() |
| cheers Yipster, I think i know the type you mention, I believe they were something to do with the oil industry, now that would be a sight, arriving on site and then deleberatly sinking half your vessle ![]() |
| "now that would be a sight" like the interior on the wall in transit mode ![]() but actually Tom has the asked solution... |
| Floating Pump Platform Design | SWomack | Boat Design | 24 | 10-16-2011 03:13 AM |
| Hovercraft Design and Theory - Excercise 1 | kach22i | Open Discussion: All Things Boats & Boating | 21 | 06-22-2011 02:25 PM |
| Trouser trout & Dive Sled help!! | trouty | Open Discussion: All Things Boats & Boating | 6 | 08-05-2005 04:16 AM |
| Hovercraft as a Teaching Tool | kach22i | Education | 0 | 05-11-2005 05:35 PM |
| Adding full tramsom motor mount / dive platform | Kaptin-Jer | Sailboats | 2 | 03-04-2004 07:59 PM |
