Old 11-29-2005, 10:04 AM
Waterrat Waterrat is offline
Rep: 10 Posts: 2
Thanks, everyone, for all of the ideas.
I am looking at the Merc Big Foot 60 or the Yamaha High Thrust 60, as I already own a Yamaha F50, and am very happy with it (also filters, spark plugs etc. are the same for both).
The price point for the F60 is almost exactly the same as a 3.0 ltr. mercruiser.
I just haven't made the final decision on which way to go...... but thanks again for your input.
All great ideas.........
Par.... any further ideas about a bow thruster? I.E. what type, size, etc.
Thanks again, guys...
Rat
Old 11-30-2005, 12:55 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,756
Bow thruster? wot you think the third motor is? clamp it on to the runabout tie the runabout across the square bit at the other end to the engines (do house boats have bows and sterns?) and there you have a system much the same as the big schooners use in New England for stern thusters (they be enginless to comply with some wierd law)!
Sotty about the Yank gibe, to may stabs at the colonials in other forums become a hazard! here we talk boats only! Over in the 'Open' we call each other names and stab each other in the back - I believe it's called fun (yeah we're a weird lot!)
Old 11-30-2005, 04:19 PM
SamSam SamSam is online now
Rep: 502 Posts: 1,682
Originally Posted by cyclops
I saw a Pontoon Boat that was a pleasure to watch. Chevy V8, 4 seconds on plane and out of sight, fast. Quiet and no outboard smell. I could move around on that one.
Kind of like this? Sam
Old 11-30-2005, 06:21 PM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Rat
Why not stick a small, high thrust, low speed, outboard or even large electric trolling motor on the bow pointed athwart ship. Reverse can be starboard. Forward can be port.
Bob
Old 11-30-2005, 06:30 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Another idea- put one outboard on centre line in the bow and one at the stern, both pointing aft. Two steering wheels and two throttle/shift boxes at the helm. Could lock one straight ahead and steer with the other, or steer with both, as desired. (Assuming the boat's on pontoons of course, a barge wouldn't work for this.) Or tilt one out of the water if you don't need it. Thus complete redundancy with no off-axis thrust, easy docking, never get stuck. (Got the idea from the old Lightning fighter jet, actually.)
Old 11-30-2005, 10:28 PM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Reading my mind? See attached drawings. Many have scoffed at this approach, but if you create enough structure to support motor wells and also some sort of debris barrier to protect the prop, I think eliminating the outboard and going with inboard/outboard setup gives you bow and stern thrusters in addition to redundant drives. This can work especially well with two electric drives since 180 degree turns plus instant reverse gives a full 360 degrees of potential thrust vectors. DuluthBoats (Gary) designed this setup which would be appropriate for a fore/aft drive arrangement (see drawing). Additional advantages: turn on a dime, parallel parking is a snap.
Houseboat propulsion-lote.ver.3.jpg  Houseboat propulsion-garyselectricdrive.jpg
Old 12-01-2005, 01:05 AM
Rep: 3125 Posts: 9,398
Don't have a clue for your application, just not enough information.
I didn't use one on either of my designs. The 52'er doesn't really need one, it's parked 99% of the time and doesn't go far when it does. The other has a pilothouse and stacks on the roof of the main cabin, making for lots of windage. This boat travels around quite a bit and cross winds can make docking interesting. Twins can help a lot, but a quick burp with a thruster can save a hard landing into a perfect docking.
There are several outfits that specialize in just this type of work. See what a search turns up and try and to get a quote.
Old 12-01-2005, 07:59 AM
marshmat's Avatar
Jonathan, I was thinking of doing almost exactly that, only with conventional outboards- I like your idea better though. What if we put a fuel cell stack in it?
Old 12-01-2005, 10:20 AM
imagineer
Rep: 58 Posts: 436
For what fuel? As soon as there is an economical, practical hydrogen storage system, it can be easily added to any electric boat. If there is a supply of hydrogen available. But it will be here before too much longer.
http://www.israelnn.com/news.php3?id=89029
http://www.worldchanging.com/archives/003473.html
http://83.219.63.174/Articles/292805...rent+class.htm
  #25
Old 12-02-2005, 01:35 AM
safewalrus's Avatar
Ancient Marriner
Hey fella's just a thought, go look at some of the hybrid's in the oil industry and scale down! Alot of what your saying has already been done by them (or are they looking at your stuff and scaling up? mmmmmm interesting thought)!
Incidentaly to to prove this I spent some five years (not all in one go!) working on one supply/work boat - first time we went into dry dock, dropped the water, went to dock bottom to take a look, apart from the bulbous bow and thruster it was a 53 metre file bottomed 'sharpie' (chines, the lot!) with twin outdrives out the bottom at the back - **** was she manouverable! comfortable in a blow too! Liked sharpies before got really into them after that!
Diesel/Electric Propulsion for Sailboats westsail42 Hybrid 250 04-06-2012 07:21 PM
Exciting New EPS Thruster (& Propulsion) brian eiland Propulsion 57 12-20-2011 09:51 AM
Sine wave propulsion JonathanCole Boat Design 116 07-03-2006 05:24 PM
Building a fiberglass shell for a small houseboat mikemac Fiberglass and Composite Boat Building 4 11-20-2005 09:57 PM
Houseboat roof forkliftking Boat Design 20 11-13-2005 01:56 PM
