| Homemade Tarp Boat Hi, my cousin and I are starting a project to build a boat of tarp around a wooden frame. I have several questions because we are inexperienced at boat building. 1.How should the tarp be connected? 2.How should we waterproof it?(Tarp seams and Wood) 3.What is the best type of wood for the lowest price that could be found at Lowes or Home Depot? 4.How wide will it need to be so it won't capzise if the length is 12ft? 5.How high should it be? Our boat will look somewhat like this <====> and its dimensions will be Length=12ft Width=?(Thinking about 5ft) Height=?(Thinking about 3ft) We are thinking fo building it so that it will fit two six foot or taller people comforatably. We are going to use a tarp shell which will require around 90ft of tarp with our estimated dimensions and around 50 to 60ft of 2x4 lumber (not exact). We expect it to take several months to raise funds for materials. |
| How much horsepower? |
| 1.How should the tarp be connected? What is the tarp going to be made from? The cheap tarps are pretty fragile and don't glue all that well. Tar sticks to them, so I'd suggest sewing the seams and then tarring the seam after. 2.How should we waterproof it?(Tarp seams and Wood) Same answer. 3.What is the best type of wood for the lowest price that could be found at Lowes or Home Depot? Make longitudinal pieces about 3/4" by 1" using straight-grained fir. 4.How wide will it need to be so it won't capzise if the length is 12ft? Three feet. Better get used to the idea that this is probably gonna be a canoe. Why tempt fate? 5.How high should it be? 12-14" depth amidships, 16-18" at the ends. Same as a canoe, if it is one. I'd sew it every few inches by hand and then use a machine and zig-zag stitch it. Sounds like fun. Alan PS There are other ways to do it of course... |
| If this is not a joke. Please, do a web search for "skin-on-frame" boats. There is alot of info out there some of it is good. After that if you still have questions we will be glad to help and you will have more detailed questions. Gary ![]()
__________________ "The hand feeds the mind." Weston Farmer |
| Hey - I've built 'tarp' boats! The trick is to use a cotton based fabric. If you can afford waterproofed fabric (like a trailer cover) , by all means use it. If you cant, get 10oz 'duck' from a fabric shop. When you put it over the frame, wrap a length of timber near the edge, and wind the wood around and around to create tension on the fabric, before you nail or staple the fabric onto the frame. Ask an upholster to show you if you are unsure. You need a tight, stretched fabric application to stop it bulging in when you put it in the water. The frame should have no more than .3 square metre of unsupported frabric area at a minium, but even more support is better. The ultimate is to get a wood matrix frame with a minumum of around 6" square of support from the frame. To waterproof the fabric, goto a hardware shop and ask for some kind of light bituminous black goo that they use to waterproof the inside of water tanks. Its longlasting, and very effective. You can get non petroleum based mixtures which are less smelly but just as effective. In Australia 'Pabco Hydroseal' was one trade name. The dimensions you suggest are a bit unwieldy. Go for 16 ft long, 2 feet deep, and 4 ft wide. It will be easier to paddle or power. You have a large fabic covered canoe basically. Lookup a few canoe designs in the local library to get a 'feel' for shape and form. Use long thin 3/8" by 1 - 1.5" strips of bendy wood over plywood (marine ply of you can afford it) frames. Paint the frame thoroughly before the fabric is applied. You will have a ball, and get a lot of fun out of the process. A cheap way to start experimenting with boat design |
| Your boat should look like this before it's skinned. ![]() This is a sailing version of what you've described, but didn't have to be. There are lots of plans available ffor these types of boats, I'd strongly recommend you get one. |
| Hi Septarowith Pars picture is exactly what you need. Dont be scared of building from plans. It will actually save you money, even if you have to pay for the plans. Even if you dont get the building exactly right the first time, it will be a whole lot better than making it up yourself. I remember being young with no money, but a real urge to get afloat. I started off with a couple of pine boards that had actually fallen off a truck (really, they were lying on the road). You will be surprised how cheaply you can get afloat. Start asking around for the price of stuff now, so you know how much you have to save. It will all happen sooner than you think. |
| rwatson I was planning on using this kind of tarp. It wil probably be heavy duty. It will look somthing like a cannoe. Here is a 5 min drawing of the top down in paint. ![]() |
| Poly may get you out for a time or two, but weather (sun in particular) tends to make poly "unravel". If you are planning on using it several times, I would go with Mr. Watsons suggestion.
__________________ Missin the waters of maine |
| We used to make kayaks from cheap canvas and simply painted the canvas with enamel paint, they last for many tears of reasonable work. We also made canoes from sheet tin, 4x2 bow and stem posts and tar for the seams, they were great, but my next door neighbour would shoot holes in the bow and sink us, it wa all good fun then. My how times have changed.....
| off topic, but Par, do you happen to have any plans for that canoe or one like it that you might be able to forward to me, that looks like it would be a fun start
| I would agree that blue tarp is not too reliable a way to skin a boat. However, at Home Depot and I'm sure Lowes also, you can buy painters drop cloths for not too much, They are cotton and I've got a couple and they're pretty tough. You wet cotton to stretch it and then when it dries you can paint it with an oil based paint. The paint strengthens the fibers in the same way resin strengthens glass cloth. Your drawing shows a strange angle change in four places. That isn't how to do it. It's easier to bend the long sticks into curves. Get a plan. Google "Geodesic Aerolite" for ideas. Alan |
I have attached a rendering of a cat. The hulls are 3.6m (say 12ft) long and 0.3m wide. These hulls can be made very easily out of 0.8mm or 1mm aluminium sheet and ply for the deck. The cat will be easily driven, nice and light (hulls could be easily separated for one person to cartop - each around 12kg) and stable on the water. The hulls do have transition lines where the sheets meet but this makes very little difference to performance. Rick W. |
| Dragon, contact me by email (click on my name) and I'll let you know what I've got available. There a few different types of fabrics you can use to "skin" a boat like this. It's a tried a true method, producing a very light, though typically delicate craft. Dacron is the usual choice for durability, toughness and workability, but it's not the only fabric. |
| Need Advice On Making A 16' Homemade Pontoon Boat | Sceptre | Boatbuilding | 3 | 01-19-2009 06:47 AM |
| VX-40's homemade! | GuestR01312011 | Multihulls | 9 | 11-19-2007 06:35 AM |
| Homemade Houseboat layout? | ATR | Boat Design | 6 | 06-30-2006 07:19 PM |
| homemade enclosure? | dogboy | Boat Design | 1 | 11-09-2004 03:32 PM |
| Homemade Ocean Master | eurotk1 | Fiberglass and Composite Boat Building | 2 | 10-06-2004 10:59 PM |
