Old 03-02-2007, 09:29 AM
Gene H Gene H is offline
Rep: 10 Posts: 5
Holding tank construction
Another project while the boat is laid up for the transmissions is a new and larger holding tank.
I'm somewhat accomplished fabricator so doing the job isn't the issue. What is the best material to build a holding tank out of? Fiberglass, aluminum or stainless steel? All other issues aside (weight, forming, shape, etc)?
The boat has a fiberglass tank now but if I had my choice, aluminum is so easy to work with and is almost as light. We're only talking about a 17" deep x 22" wide x 38 " long tank.
GH
Old 03-02-2007, 10:37 AM
Lancerbye's Avatar
Lancerbye Lancerbye is offline
Rep: 10 Posts: 85
Holding Tanks
I recently aquired a Lancer 44 motor sailer which was very well maitained. The holding tank is unusual but practical and functional. It was made out of 2- 10in. i.d. White type PVC pipe each about 5 ft. long joined together and stacked one above the other with reducing Tees 10 x2 and the ends capped with PVC slip joint cap. This whole thing is made out of PVC pipe which is easy to plumb to because of the available fittings cheap. and glued together.You get 3.4 Imp. Gals per foot of pipe. Another type to consider.
Old 03-02-2007, 03:15 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
GH
We just had to replace our fresh water & holding tanks. They were aluminium. When tour fellow drove straight to the Gibson plant to get the new plastic tanks, he took the alums to show them the teeny pinholes. The yard forman didn't even look. He grunted in agreement & told our guy to pull behind a far building to duscard them. When he rounbded the corner he saw a MOUNTAIN of replaced aluminium tanks. Someday we may be drinking sodapop from these discards. Gibson is claining that chlorene is the culpert.
Just a firsthand experience with aluminium tanks. Good luck.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 03-02-2007, 04:22 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
BARR - none...
Hello...
We have used these guys for all our primary tanks and sumps for tubs and showers - black and grey water - and freshwater - diesel remains welded aluminum...
These tanks are fantastic - throw them off your roof into the parking lot - fill them up and pressure test them beyond specs. and they just dont burst - best of all - no leaching of the inevitable '5 year stink'...
Shipping might cost a bit - you may have a local group doing same - get out your Yellow pages and start looking up Agricultural tank Mfgs'...
See http://www.barrplastics.com/plastic_fabrication.htm - pay the money and never think about it again ...
Cheers...
SH.
Copper holding tanks and photos of 1946 Elco joshbygosh Marketplace 1 01-21-2007 07:29 PM
Tahoe Q-3 2001 Lights and Fish Holding Wiring Fes Boat Design 0 07-20-2006 07:47 PM
Bait tank/ holding tank fabrication question searaytuna Fiberglass and Composite Boat Building 20 11-17-2005 04:56 PM
Polyethylene holding tank Terry Materials 2 03-16-2004 10:19 AM
Fuel, water, black water tank construction kudu Boat Design 12 07-25-2003 06:54 PM
