| High-Speed Waveless Sinusoid Propeller Have you ever saw this kind Propeller? How it works? What do you think about it? |
| cant say i have can only imagine vertical waves now ( but havent given it a real deep thought ) why mounted at the stern of a so called waveless boat design missing a front prop? should this not be posted at modern paddlewheels or under the propulsion threads? must say its inventive ![]() |
| This device works by the viscosity of laminar flow which is increased by the weight of water falling into the v between the 2 wheels. Actually a Tesla turbine might be a better way to use laminar flow as a propulsion medium. Does it have a pass through tube from the front? But if the disks are solid at those angles, maybe the boat would pivot around the bow! |
| This device works by the viscosity of laminar flow which is increased by the weight of water falling into the v between the 2 wheels. Actually a Tesla turbine might be a better way to use laminar flow as a propulsion medium. Does it have a pass through tube from the front? ================================================================ There are not 2 wheels, that's 2 flexible lamina. It is suitable for twin-hull boats that Sinusoid Propeller can put into front or middle of the boat. |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 01:20 AM |
| bigger props faster ship? | Peter H | Boatbuilding | 23 | 02-01-2010 12:08 PM |
| Long - Skinny Power Boats | SAQuestor | Boat Design | 164 | 11-12-2009 05:28 PM |
| Propeller Speed Theory | batboat | Props | 9 | 05-23-2009 06:29 PM |
| Full Displacement of semi | tdamico | Boat Design | 51 | 02-18-2004 09:42 AM |
