#46
#47
Sorry, but I don't know what you mean by separation will not overcome the front resistance. When you say "front resistance" do you mean the resistance due to wave-making? Separation drag can increase the frictional resistance by a factor of 20% or sometimes much more. And that is from each of the three surfaces (hull and 2 duct surfaces). |
#48
Every man has an idea that will not work. Leo. |
#49
| the frictional resistance by a factor of 20% or sometimes much more. ================================================== diffrent speed has diffrent frictional resistance. Usually, frictional resistance is ignored in ship design. 20% frictional resistance may be your are designing a torpedo. |
#50
as agent for that free deal i ordered a new free mobile phone with a P4 pc as gift to do the maths |
#51
| A pipe D=1.2m. water speed=1000m/s, hydraulic pressure=10m deep, energy loss=0.0016% per meter. This is the result that find by google. |
#52
| is that one meter tube going trough the water sound barriere? offcourse there are a few more "and's" to consider |
#53
| If you have a boat, you buy a square meter sheet metal, put into water at side of the boat, run a hour, you will get the result. |
#54
#55
#56
Leo. |
#57
| help for boat designing sir can i get more information about your design.pls now am working as a fiberglass engineer. |
#58
| help for designing a boat sir can i have more details of your design ,pls. |
#59
| sibyjoseph, I am not a boat design, but I will give you a 3D design of the Waveless Boat, it will help you to construct. |
#60
| I like this project because it's making me think outside the box. It challenges conventional wisdom to an extreme I might add. Cutting down on wake while doubling or tripling surface area. Every calculation making wake a by-product of resistance and resultant drag will have to re-evaluated if you pull this one off. Perhaps my last offering on this is this: Water is not a better lubricant than air – period. You might want to look a some of those Russian patrol boats with stepped hulls. They inject pressurized air at the step. What affect would this have - for propulsion; combine an air jet stream with a water jet stream located all around the inside lower lip of the bow foil opening. This might lower drag, but at the expense of decoupling the water flow from the curved neutral foil. Do you want the water to cling to the hull and produce drag? Do you want the water to decouple from the hull and reduce drag? Is wake always a direct product of drag? I really don’t know myself, just asking. |
| Are we making any real design improvements?? | Wardi | Sailboats | 199 | 11-04-2008 03:33 AM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| LOWWWW speed hyrdrofoil? | Bill Fish 6 | Boat Design | 3 | 12-18-2004 10:12 PM |
| Concept Boat Design Contest | Tad | Boat Design | 16 | 09-17-2004 11:13 AM |
| Speed Limits Coming??? | sharkeymarine | Powerboats | 12 | 03-06-2003 11:48 PM |
