  #31
Old 07-28-2005, 04:42 AM
waveless waveless is offline
Registered
Rep: 10 Posts: 92
Sorry, I have made mistake in my design, I have changed the design, take a look again.
Why no people point out my mistake?
  #32
Old 07-28-2005, 09:12 AM
woodboat woodboat is offline
Rep: 14 Posts: 312
I think your design looks very similar to this
http://foxxaero.homestead.com/indrad_061.html
  #33
Old 07-28-2005, 10:22 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
Mistake?
I'm still trying to figure out what's changed, as I have no side-by-side to compare the change to. You don't make it easy for us.
Looks like you added a "Duct" label.
Did the propeller/engine location change in one of the schemes?
Hey, Woodboat, I think his design is more of a curved hydrofoil, but with zero lift.
The design seems to depend on water clinging to the hulls surface and the curve duct structure, and not separating, which is what good foils do, right?
I'm not big on the propeller in this design; the shroud or foil does not act as a flow feeder/controller to the thrust element (propeller). All I foresee is debris being directed into the blades with no chance of deflection or escape. What if you hit a floating log?
I think a cleaner thrust element would be water jets whose turbulence is evened out by the hull and neutral foil. There will be lots of friction loss, but lower disturbance than a free (open) system.
I've seen hydrofoils with curved foils, if you could level out the wake with pressurized air like a hovercraft at the stern you may be on to something new.
Keep working on it.
  #34
Old 07-28-2005, 11:34 AM
Registered
Rep: 10 Posts: 92
woodboat,
If you can read mechanical drawing then you will understand what waveless boat looks like.
  #35
Old 07-28-2005, 11:57 AM
kach22i's Avatar
Architect
Just did a Google image search and found this. Does this look low wake? Would you really want to try to operate it in a shallow river?
Just food for thought.
  #36
Old 07-28-2005, 12:05 PM
kach22i's Avatar
Architect
Does anyone know what a "A" foil desgn is?
Bugatti Design
http://www.******************/Bugatti...nced_Hulls.htm
The special foil design destroys the wave geometry passing through the A-foil, creating a flat water surface under the hull for a very smooth ride.
[IMG]http://www.******************/images/100ft_BUGATTI_YACHTS_Illuminations.jpg[/IMG]
  #37
Old 07-28-2005, 12:57 PM
Registered
Rep: 10 Posts: 92
kach22i,
A-Foil Motion Control System Hydrofoil
I think that A-Foil's screw is fixed at the tail of the boat, and it's bottom is not a duct. this why the wave is generated at the tail. She is not efficient, and the energy will diffuse to the open water. also it is difficulty to turn round.
  #38
Old 07-28-2005, 01:15 PM
Registered
Rep: 10 Posts: 92
I have a lot of unti-traditional designs, I feel that traditional design of airplane is very babyism. Because here is boat design forum, I do not talk about.
  #39
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1726 Posts: 1,244
Originally Posted by waveless
woodboat,
Hi again!
It is not clear to me how you estimated the resistance components in your original post.
What are the wetted surface areas of the ductless vessel and the waveless vessel?
What length are the vessels and what is their optimum speed?
Regards,
Leo.
  #40
Old 07-28-2005, 01:39 PM
kach22i's Avatar
Architect
Waveless I don't want to talk past you, through you, or around you - I want to see Leo able to help you.
I need to talk out loud about the Bugatti design for a moment, as it has my interest for now. If I make a false assumption - please feel free to correct me.
"A" foil is just that, a foil that looks like an "A" in section or an upsidedown "Y".
This paticular Bugatti is built like a narrow sponson catamaran, with a tunnel like middle hull, which compresses air to the stern for lift and to level out the wake. The craft is very much like a SES (Surface Effect Ship), except there is no bow or sten skirt to contain the air under the craft body. The "A" foils attached to each sponson/pontoon near the bow and lift up the front of the boat/craft.
There is more "wetted area" on this design than a traditional hydrofoil, but I'll assume it's better in heavy seas and has greater payload.
How close did I get with my analysis?
Now that I did this, maybe I can tackle the design by "Waveless", I'll admit I need more and better drawings and a photo of the bathtub model. My imagination is not limitless, but even I could use a 3D view of this creation.
  #41
Old 07-28-2005, 01:43 PM
Registered
Rep: 10 Posts: 92
1,The resistance is related to section plane under water surface. for principle, waveless boat can reduce the front resistance to 0.
2.the wetted surface areas is about two time of the ductless vessel.
3.The boat length is no limit, and it's speed can't be very fast, keep the duct full of the water.
  #42
Old 07-28-2005, 01:51 PM
Registered
Rep: 10 Posts: 92
I am not possible to do the test, I only want to talk the principle with the experienced engineer and researcher.
Thank you to talk to me.
  #43
Old 07-28-2005, 02:08 PM
Registered
Rep: 10 Posts: 92
kach22i,
I am a good computer engineer, I will give you a 3D view. At moment, I have no 3D software in my computer. I will reinstall CAD software again.
Wait some time, because I have to finish something.
  #44
Old 07-28-2005, 02:09 PM
My pleasure.
If the duct is about the same length as the vessel, then it seems to me that the vessel has almost three times (not two times) the wetted area of the ductless boat. You might be able to reduce wave-making using your method, and that is very good for some waterways. But I doubt that your vessel will be more efficient overall because of the large frictional resistance and the large form drag. In fact, you might end up with flow separation on the hull, the inside of the duct, and on the outside of the duct.
  #45
Old 07-28-2005, 02:16 PM
Registered
Rep: 10 Posts: 92
1,It is right 3 times.
2,Water is a good lubricant, the frictional resistance is very small.
3,If separat from the hull, it will not overcome the front resistance.
Are we making any real design improvements?? Wardi Sailboats 199 11-04-2008 03:33 AM
LOWWWW speed hyrdrofoil? Bill Fish 6 Boat Design 3 12-18-2004 10:12 PM
Concept Boat Design Contest Tad Boat Design 16 09-17-2004 11:13 AM
Speed Limits Coming??? sharkeymarine Powerboats 12 03-06-2003 11:48 PM
