Old 11-15-2007, 11:08 AM
babakshabani babakshabani is offline
Rep: 10 Posts: 10
High Speed Boat
Hello to all,
How do you think about the future form of high speed boat ?
do you have any idea?
Old 11-15-2007, 12:19 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
Robotic, because people are too delicate.
Video:
http://video.google.com/videoplay?do...arch&plindex=0
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 11-15-2007, 01:47 PM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 503 Posts: 1,032
Thanks a lot...nice video!
Old 11-15-2007, 01:52 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
bigger more stable boat would have been nice too
Old 11-15-2007, 01:57 PM
Naval Architect
ASD....ASD....ASD....by OR
Old 11-17-2007, 10:22 AM
Rep: 10 Posts: 10
Old 11-21-2007, 09:32 AM
RatliffFranklin RatliffFranklin is offline
Rep: 17 Posts: 191
Future Concepts
Originally Posted by babakshabani View Post
Hello to all,
A hull that rides above the surface attached by struts to a submerged supercavitating pod.
Old 11-21-2007, 10:50 AM
kach22i's Avatar
Architect
Excellent suggestion, but let me ask or state a few things.
1. Does not a pod (or submerged sponson) lose it's buoyancy with air bubbles all around it?
2. Most Swath's for this reason are slow, right?
3. To get around this problem large (and thick) mid-foils which provide lift at speed and buoyancy at rest have been tried, see images below.
Mid-Foil by Navateck
http://www.navatekltd.com/midfoil.html
Old 11-21-2007, 10:56 AM
Rep: 17 Posts: 191
Supercavitating Vehicles
Supercavitating vehicles, such as the Shikval torpedo, aren't surrounded by bubbles. They're inside one big bubble. The Shikval has rear skids that ride on the surface of the water, except that water surface is underneath the ocean.
Old 11-21-2007, 11:06 AM
kach22i's Avatar
Architect
http://actuajihad.blogspot.com/2006/...eaponry-i.html
http://en.wikipedia.org/wiki/Supercavitation
Supercavitation is the use of cavitation effects to create a large bubble of gas inside a liquid, allowing an object to travel at great speed through the liquid by being wholly enveloped by the bubble. The cavity (the bubble) reduces the drag on the object and this makes supercavitation an attractive technology; drag is normally about 1,000 times greater in water than in air.
VA-111 Shkval
http://en.wikipedia.org/wiki/VA-111_Shkval
The VA-111 Shkval (from Russian: шквал - squall ) torpedo and its descendants are supercavitating torpedoes developed by the Russian Navy. They are capable of speeds in excess of 200 knots (approximately 370 km/h).
http://upload.wikimedia.org/wikipedi.../a8/Shkval.jpg
http://upload.wikimedia.org/wikipedi...hkval_head.jpg
Questions:
1. How "perfect" or complete is the bubble?
2. Are the fins controlling direction, altitude and attitude?
Old 11-21-2007, 11:13 AM
Rep: 17 Posts: 191
Shikval
The Shikval has a speed of over 200 mph.
The swash plate nose is in contact with the water and deflected to provide pitch and directional control.
One theory of supercavitating flow predicts the bubble will collapse at around 400 mph. Another theory, based on hypersonic flows, predicts there is no upper limit.
Old 11-21-2007, 11:29 AM
kach22i's Avatar
Architect
I'm going to get a little crazy on you for a moment, I trust you don't mind.
1. Even a super thin F-104 style vertical fin connecting the hull to the submerged pod will cause an explosion of water and a heck of a lot of spray.
2. Could the leading edges of the vertical supports also bleed out air?
3. This is the wild idea part; maybe magnalift support between the hull and pods? Some electro-magnets would be lifting, some pulling to maintain a constant distance.
4. Magnetic fields just to far fetched at this point in time, too Sci-Fi?
5. The Shikval is a kind of underwater hovercraft in my eyes, I like the concept. I've read about it for the first time only a few years ago. Perhaps in this forum.
http://s184.photobucket.com/albums/x295/kach22i/
Old 11-25-2007, 06:15 PM
FranklinRatliff FranklinRatliff is offline
Rep: 84 Posts: 294
Good question. One theory of supercavitating flow, based on steam forming in the partial vacuum of the cavitation bubble, predicts the cavitation bubble will collapse at around 400 mph when the gas pressure can no longer sustain it. Another theory, based on hypersonic flows, predicts there is no upper limit since the bubble depends on the momentum of the diverted water not internal gas pressure. If the hypersonics based theory predominates, maybe no bleed out.
Old 11-25-2007, 07:50 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
George, One problem with your system is that, if it needs an above water vehicle, what is the need for the torpedo? Just use a missile in the first place.
Which brings up another point. What is the advantage of a fast torpedo over a sub launched anti-ship missile? Both leave a track that can be used to locate the launcher.
This is getting off the track of the thread, or maybe not.
Tom Lathrop
Old 11-25-2007, 08:02 PM
Rep: 84 Posts: 294
Diectional Control
For a couple of things, riding on a supercavitating torpedo would give the boat ride height control you can't get with a missile. To get any real range, the boat would also require one of the waterbreathing propulsion systems that are now in the experimental stage.
The Russians developed Shikval so that whatever happened to the sub that fired it the target aircraft carrier would be gone in a mushroom cloud before anyone had time to think about countermeasures.
Very high speed prediction fede Boat Design 17 05-31-2009 09:25 PM
High-Speed Waveless Boat waveless Boat Design 82 10-10-2005 08:01 AM
best hull design for high speed boat almesbah Open Discussion: All Things Boats & Boating 8 07-15-2004 02:46 PM
High Speed Narrowboat Nick Ireland Boat Design 11 05-30-2003 07:56 AM
high speed patrol boat Boat Design 5 02-14-2003 11:02 PM
