Old 11-26-2007, 08:56 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Another twist:
Imagine that the upper aerodynamic part detaches and flies away on it's own.
Imagine the submerged pod is not rocket powered, but something more conventional.
Is what we have now considered an aircraft carrier?
Is it a "Flying Sub"?
Maybe it's just a boat and a dinghy.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 11-26-2007, 10:00 AM
RatliffFranklin RatliffFranklin is offline
Rep: 15 Posts: 191
Mothership
Originally Posted by kach22i View Post
Another twist:
Since the surface pod would not be sustaining the stresses of a conventional hull, it would not need to have a structure as robust as a conventional boat so I suppose it could be designed to operate as an independent aircraft.
Old 11-26-2007, 03:20 PM
zaltiy zaltiy is offline
nav.arch/mar.eng
Rep: 10 Posts: 3
The supercavitating idea based on shkval torpedo working principles looks interesting at the beginning. However the major drawback even if you manage to fit your wetted surface into this air babble there are not a lot of things you can do with maneuvering as the babble is extremely sensitive to direction change. By the way the fins are used to pilot the torpedo with the aid of the gases. Supercavitation is already applied to hull forms i.e. supercavitating hulls and even special hulform designs are in the market that use air to reduce the wetted surface area of the hull with approximate 3% penalty on the engine's power (in order to generate and sustain the air babble).Thus without even discussing if this could be a cost effective solution, even if you do such a design it might be quite difficult to maneuver it, unless you want it to go only straight !
Old 11-26-2007, 04:03 PM
Rep: 15 Posts: 191
Predictability
I've seen a 300 mph boat in action. The predictability and consistency of a submerged supercavitating pod would be a huge improvement. Trust me on that one.
Old 11-27-2007, 10:33 AM
kach22i's Avatar
Architect
I'm thinking that the vertical fins which hold the upper body to the submerged supercav pod could pivot. The fins would then be acting as rudders without need for other rudders on the pod below.
Also I've seen in thrust vectoring diagrams where increasing the thrust on one side tends to pull the rest of the thrust with it, and in turn results in thrust vectoring without baffles or fins or elevator plates.
Old 11-27-2007, 11:06 AM
Rep: 15 Posts: 191
Control Systems
Either or both could be doable.
Old 11-29-2007, 01:09 PM
kach22i's Avatar
Architect
http://www.darkroastedblend.com/2007...lth-ships.html
(image credit: Popular Mechanics)
Old 11-29-2007, 01:44 PM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
from here i saved some pics before they went of the net and i went berserk, which may be a good qualifacition designingthis stuff
High Speed Boat-naamloos-1.gif  High Speed Boat-naamloos-2.gif  High Speed Boat-naamloos-3.gif
Old 11-29-2007, 02:12 PM
kach22i's Avatar
Architect
I never knew there was a "very shallow water configuration" before.
Way cool.
  #25
Old 11-29-2007, 10:09 PM
FranklinRatliff FranklinRatliff is offline
Rep: 15 Posts: 350
Covert Ops
For covert ops why not just make a semi-submersible V-hull or tunnel hull? Submerge it for stealth then blow the ballast tanks when you need to haul ass.
  #26
Old 11-30-2007, 12:59 PM
kach22i's Avatar
Architect
It's been suggested/rumored that the Special Operation Forces (SOF) already has SOC of this type.
Similar to this:
http://www.globalsecurity.org/milita...ship/boats.htm
Maybe not high-speed in the traditional sense, but high-speed in rough weather which is more important anyway.
Very high speed prediction fede Boat Design 17 05-31-2009 08:25 PM
High-Speed Waveless Boat waveless Boat Design 82 10-10-2005 07:01 AM
best hull design for high speed boat almesbah Open Discussion: All Things Boats & Boating 8 07-15-2004 01:46 PM
High Speed Narrowboat Nick Ireland Boat Design 11 05-30-2003 06:56 AM
high speed patrol boat Boat Design 5 02-14-2003 10:02 PM
