| High Density Plastic River Boat First let me say this is an awesome site! Myself and many in my circle of friends are diehard fans of the old Coleman Crawdad.....I think like 1998 and older. The problem is they don't produce them anymore. We got in a conversation about how great it would be to buy the mold, which I'm sure that A - they wouldn't sell it B - if they did, it would be outrageous We then shifted to building our own. I was hoping you folks may be able to shed a somewhat general light on what kind of expense we are looking at? We would want to build it similar, not exact of course....Just need someone to build the mold, then someone to inject them I guess? We could handle all the tubing and framework ourselves.... What do you guys think? |
| With all the changes in the small boat industry since the onset of the current recession, it looks like that style of boat has been sold off to Pelican International as the Intruder Jonboat. http://www.directboats.com/20in12jonbo.html Pelican could be producing their own version of the design as an original, but it looks awfully similar. http://www.pelicansport.com/index.ph...at=fishingboat This boat is either rotomolded, or it is thermoformed. Rotomolding is the most expensive production tooling of the two, but it can be used for many more parts than can a thermoforming tool. The least expensive way into the business would be with a thermoformed boat, if it can be done to satisfactory strength requirements. A production rotomold tool will set you back about $2500 per linear foot, give or take, and that does not account for prototypes, design fees, a high temp prototype epoxy tool to test the final design, etc. Thermoforming will also get you for the design work, the tool cutting and a whole slew of prototypes until you get it ready to produce as a final boat. Then, of course, you need a marketing budget that will allow you to get the boat out in front of all the potential buyers, be they individuals, or retail companies. Cha-Ching. |
| Yeah, Pelican makes a "new" crawdad.....twice as heavy as it is double hull ram-x.... I'm talking about the older style, single hull, aluminum frame..... If you type "coleman crawdad" in google images, it is the first one that comes up. |
| Well, it would seem that you'd want to ask yourself why the first boat went away, even though it was backed by a very big time company, and the heavier version is now being produced by someone else. |
| I'm sure the process would be the same I guess on either one... |
| I've fished in both....the old one puts the new one to shame. I think it was like everything else...."let's make it better"....and by doing so, IMO, and many others, they have ruined it. This is the kind of boat that you want to be able to slide down a riverbank to put in, and pull it back up the bank to take out....weight is a factor. Double hull equals double weight. |
| It could also mean double+ durability. Not a small consideration for a regular guy on a fairly modest income. Like anything in boat design you have to give something, in order to get something. Engineers say, "there's no free lunch", but it's all the same. You need to carefully describe the design needs in order to decide just what materials and engineered properties are needed. Aluminum, wood cored laminate, plastic rotomold, dual wall plastic rotomold, thermoformed parts later joined, etc. One needs to carefully balance all the needs in order to arrive at a truly great final decision as to chosen materials. |
| What do you like about the crawdad that can't be done better by other designs? IMHO there are many more efficient, lightweight options that can be paddled, pedaled, rowed or motored and are quiet unlike the noisy aluminum. http://www.northforkoutdoors.com/ There are also 1 and 2 man "bass buster" boats hard and soft of various sorts of comparable or lower price and higher quality. I do a little fishing also from time to time. Porta Quote:
| I'm reasonably convinced the older version was vacuum formed not rotto molded. I had one back in the mid 80's and it was light and one of the quietest fishing boats you could ask for. They tended to pull their fasteners along the aluminum framing, were easily damaged or distorted and UV made them ugly pretty quickly, but they were light and quiet. |
| I looked at a bunch of pictures, and it seems to be a very practical boat for its intended purposes. But instead of trying to reproduce a production hull using production methods and materials, why wouldn't you and your buddies just get together with a pile of 1/4" plywood and some stick lumber, and build some boats along the same lines? You could probably also do a stitch and glue version..... |
| Heres another hard hull possibility that is cheap, comfortable, very stable and can be powered several ways. If you need more room, get 2, and maybe still be lighter than the crawdad. Porta Quote:
| river boat in greek river evros | petk98 | Wooden Boat Building and Restoration | 2 | 10-23-2007 02:17 PM |
| High Density River Silt & Mud Dredger | Wellydeckhand | Boatbuilding | 16 | 05-22-2006 01:14 AM |
| Recycled Plastic/Plastic Lumber Hulls for Pleasure Boats? | Keith King | Boat Design | 8 | 09-29-2004 02:17 PM |
| fluid density in Hydromax | DaveB | Software | 1 | 07-15-2004 03:48 AM |
| Density of Salt water | Willallison | Boat Design | 18 | 02-20-2004 12:12 PM |
