| help tripping bracket design how to design tripping bracket how is it different from ordinary ones |
| If you load up a narrow but deep beam you will eventually see the bottom of it deflect sideways as it starts to collapse this is well before its yield. We call this tripping , if you attach triangular brackets along the beam normal to its direction you will stop this initial collapse hence "tripping bracket" As to how to design it you need an Engineer or a scantling rule book. Hope this helps good luck
| how to install a P-bracket? | Ivan R | Fiberglass and Composite Boat Building | 6 | 11-22-2004 01:49 AM |
| help with transom bracket | anthony c | Boat Design | 0 | 09-26-2004 03:05 PM |
| Outboard Bracket Help | JOHN P. | Powerboats | 9 | 04-22-2004 07:24 AM |
| Transom Bracket | fletch44 | Boat Design | 1 | 04-18-2004 09:09 AM |
| outboard bracket | Boatbuilding | 1 | 03-07-2004 07:35 AM | |
