Old 11-11-2003, 08:17 AM
Help, Thrust Generated By Outboard
IN ORDER TO DESIGN A MOTOR MOUNT I NEED TO KNOW THE MAXIMUM THRUST GENERATED BY AN OUTBOARD OF A GIVEN HORSEPOWER. THE APPROACH I HAVE BEEN USING TO COMPUTE THE THRUST APPEARS TO YIELD VERY LOW THRUST VALUES. MY METHOD IS AS FOLLOWS:
GIVEN: 130 HP OUTBOARD WITH A PROP GOOD FOR A TOP SPEED OF 40MPH
FIND: THRUST IN POUNDS
1 HP = 550 FT LBS/SEC; AT 40MPH A DISTANCE OF 587 FT WILL BE TRAVERSED IN 1 SEC.
WORK = POWER OVER A GIVEN TIME
THRUST X DISTANCE COVERED IN A SEC = POWER GENERATED IN A SEC
THRUST X 587FT = 130 X 550 FT LBS/SEC X 1 SEC YIELDS A THRUST OF 122 LBS
THIS IS OBVIOUSLY INCORRECT, PLEASE HELP
Old 11-11-2003, 04:45 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
Not to comment on your method but 40 mph is not 587 ft/sec. More like 58 ft/s
Old 11-11-2003, 05:33 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Most engines produce maximum thrust at low speeds. I know this doesn't make your job easier ;-P
However, if you figure out the drag on the boat at, say, 5knots, and then guesstimate the acceleration, you should be able to figure out something close to the thrust.
Old 11-12-2003, 03:02 AM
dougfrolich dougfrolich is offline
Rep: 140 Posts: 560
Try (326*Shp*e)/Va
Shp=Hp at the Shaft
e= Propeller efficiency
Va=Speed of water at prop
Given your problem; 130hp I assume is the net hp at the shaft.
I assume the propeller is adequately sized
I assume your boat is fair, and water fed to the prop is clean.
(326 x 130 x .70) / 37 = 802 lbs. of Thrust
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 04:54 AM
outboard powering a cat EDM Powerboats 9 09-23-2005 06:27 PM
Outboard conversion on displacement hull Allan Powerboats 7 09-13-2005 09:53 PM
Thrust tunnel Jasen Boat Design 8 06-05-2005 02:08 PM
Prop Thrust Calcs / Bow Thrusters jocko_nc Boat Design 0 04-20-2004 07:32 PM
