Old 01-14-2011, 04:55 AM
sharp.1995 sharp.1995 is offline
Help for a student!?
Hi I am new to these forums and have only just registered, so hello!
I am a student in the UK and am hoping someone on these forums can give me the text-book definition for "Scantlings" ?
I have been looking for some time and have struggled to find clear definition; as far as I understand Scantlings are the structural members forming the boat / ship ? does this include plating ? or just the frame work ?
ANY advice would be hugely appreciated,
Many thanks
Shaun.
Old 01-14-2011, 07:47 AM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
Effective dimensions of load carrying elements, to make them strong enough.
Under "effective dimensions" it is understood " effective in load carrying", when end attachments, cut-outs and the like are taken to account.
example: calculation show, that plating need to be 3.7mm thick; you chose either 3.5 or 4.0 to build.
example: frame section modulus has to be 10cm3; any flatbar, angle, HP with section modulus above ~9.8 will do;
and so on.
All the stresses in my designs are 95% of permissible.
Old 01-14-2011, 02:48 PM
Rep: 3125 Posts: 9,397
I almost agree in the above definition, except that you should leave off the "effective in load carrying" part, because this has nothing to do with the scantlings.
In fact I'd use a different approach, such as scantlings are the physical dimensions and descriptions of the elements (structural or other wise) on a boat.
Anyone that's had to preform repairs can attest to the lack of "effective in load carrying" potion of the Perm's description, particularly in racing craft, where often the "effective load carrying" thing has been found a wee bit short in the calculations department.
Old 01-15-2011, 06:40 AM
Rep: 1493 Posts: 7,447
Scantlings are the sizes but not the specification of material. For example, a frame can be 3"X7"; those are the scantlings. The specifications of materials would be: hard pine or oak.
Old 01-15-2011, 12:18 PM
I disagree, though from a technical stand point you may be right Gonzo. All the scantlings I've written included material choices if required. (1.5" x 2.75" sheer clamp, hardwood, white or live oak preferred), etc.
I consider the specifications the general dimensions and generally published hydrostatic/dynamic figures, such as LOD, LWL, AVS and Cp.
question from a student Cleetus Boat Design 20 12-03-2006 07:29 PM
Westlawn Student Needs HELP! dishsail Powerboats 2 07-27-2005 08:17 PM
Help needed by student..... Dave_raul Boat Design 9 02-26-2005 04:25 PM
student Ekmecic Milan Open Discussion: All Things Boats & Boating 1 10-31-2004 04:07 AM
UK Design Student Archive Services & Employment 0 06-12-2001 04:02 AM
