| Help, School Project what would be the best way to make a miniature boat out of a 20 oz. soda bottle, baking soda and 6M acetic acid? i need it to pass the final. |
| What is 6M acetic acid? |
| I know this sounds more complex, but could you build a hull then use a single-cylinder piston engine to drive a prop. The baking soda + acid combination should provide air (or CO2) at sufficient pressure, and the 'engine' could be a modified stem engine (have a look on the web). This gives normal control, and good efficiency. It would also run from a compressor. Tim B.
| oops Quote:
ICB, you could keep the boat going straight with some kind of rudder sticking into the water, far aft, just like the fins. But you do need to prevent the boat from rolling, so the rudder can work. Usually you put some kind of flotation on either side, but there are lots of ways to do that. Maybe you could look at some boats on the web for ideas. Beach Cats is about sailboats, but it has good catamaran pictures. And there are trimaran pictures here: http://www.trimarans.com http://www.corsairmarine.com http://www.windrider.com http://www.trihulls.com |
| Project managment/Design job available? Turkey and/or multihulls preferred. | catweaselcat | Services & Employment | 0 | 11-20-2004 04:06 PM |
| Need a website for my daughters school project | Mommy3EMA | Open Discussion: All Things Boats & Boating | 3 | 05-18-2004 09:20 AM |
| About a school project | jb | Open Discussion: All Things Boats & Boating | 0 | 10-14-2003 08:52 AM |
| School project | jb | Boatbuilding | 0 | 10-07-2003 05:46 AM |
| school project | Boatbuilding | 1 | 02-20-2002 12:23 AM | |
