Old 01-18-2005, 05:22 PM
fede fede is offline
Rep: 34 Posts: 281
Help with Savitsky Prediction and shaft inclination
Hi, I'm working on a spreads. for planing hulls using formulas taken from Principles of Yacht Des.
The thing that's driving me crazy is that variations of shaft angle of about 5 deg. give back an increment /decrement of required power of 600 hp (from 500 to 1100) on a hull I'm using as a sample.
Is that possible that a change of 5 deg in shaft inclination gives such a different result????
Old 01-18-2005, 06:16 PM
mistral mistral is offline
Rep: 22 Posts: 154
i'm working on that calculations too, write me at crispilo@tiscali.it
ciao
Mistral
Old 01-20-2005, 06:08 AM
Rep: 34 Posts: 281
Solved...thanks
Old 06-08-2005, 07:52 PM
Akeswins Akeswins is offline
Naval Architect
Rep: 10 Posts: 137
Hey Guys, are u students in "Laurea in ingegneria nautica" ????
However an increment of 600 hp caused by a variation of 5 degree is more than acceptable. The max efficiency of planing hulls is limited in a range of 2-4 degrees , then resistence's curve jump very high.
Bye
Old 06-08-2005, 08:08 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Now you have me interested in how such large horsepower changes occur in the given size of a craft. Could you pick a well known make and model and engine size with HP graphs to show the changes that must take place in the real world we boat in? Thank you.
