Old 01-29-2006, 06:48 PM
chocomono chocomono is offline
Rep: 10 Posts: 10
Help SAVITSKY power prediction
Hello
I have to do a power prediction for a patrol of 20m in length using Savitskyīs method. The length is the only data i have, and I donīt know what parameters I have to suppose and how to get the power by this method. Can u help me, please?
Thanks
Old 01-29-2006, 06:54 PM
Willallison's Avatar
Rep: 2280 Posts: 3,467
I don't think that you could reliably do a power prediction with so little information - whether by Savitsky or any other reasonable method.
There are a number of variables that you could assume - like CG position for instance, but others, like displacement can vary so much that your predicition could by out by multiples of the correct number
Take a look at this thread. Amongst other things, there is a link to a spreadsheet (by Dingo) with savitsk's
Savitsky Power Prediction
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 01-29-2006, 07:04 PM
Rep: 10 Posts: 10
Thank u
Thank u very much Willallison
I saw Dingoīs sheet, but I donīt have enough information to use it, and I think I canīt use any software. I have to explain the method and suppose as many things as necessary to get the power.
Thank you again
Old 01-29-2006, 07:16 PM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 503 Posts: 1,032
Give me displacement, hull shape (round or chine), propulsion system and power or speed.....
Ah - ok - this is a 'school' question - thats different. You must go look at as many similar boats as possible and note down as much info about them as possible - displacement, deadrise, CG etc etc. Many things you wont be able to get info on - like CG for instance, so you will have to make an educated guess about its position
Will
www.imaginocean.net
Old 01-29-2006, 08:01 PM
Rep: 10 Posts: 10
Data base
Yes, itīs a school work. I donīt know anything about high speed vessels, and the only data I have is the length. I have to talk about forms, resistance, porposing, speed coefficient, give a table of planing vessels against Froude number and do a prediction of power by savitsky (I have to give a number).
I made the following data base and I have found some information about the other things (not many), but I donīt know how to do the savitsky prediction of power.
Thank you very much
Old 01-30-2006, 01:45 PM
Rep: 10 Posts: 10
Hello
I have read that the best option for this kind of patrol is:
chine forms
waterjets propulsion
and I can suppose:
displacement about 20 T
max speed about 55-60 knots
service speed 15-25 knots
How can I do the power prediction?
Can u tell me something about the speed coefficient?
Thank you
Old 01-30-2006, 02:03 PM
Naval Architect
20 t seams to be to optimistic for such top speed and waterjet propulsion plant...
Anyway according to my KR system you will need 3100 hp abt. in order to reach 57.5 knots, but as sed in my opinion the displacement would be btw. 25/30t.
KR = (BHP)^0.551 / (Displ.)^0.476
Old 01-30-2006, 02:38 PM
Rep: 10 Posts: 10
Thank you very much Otto,
I will consider your prediction but I have to do it by Savitskyīs method.
Thank you anyway. I will keep in mind your power prediction and weight
Old 01-30-2006, 03:02 PM
Naval Architect
Savitsky ,according to my own experience based on model test results, is too optimistic...
The input for a such patrol boat would be:
Length at waterline = 17.00 m > 55.77 '
Beam = 5.2 m > 17.1'
Deadrise angle = 18.5 deg.
L.c.g. = 6.3 m > 20.7 '
Displacement = 27.5 t > 60'627 lbs
try to calculate the bare hull resistance with Sav. with these data...
Old 01-30-2006, 07:47 PM
Rep: 10 Posts: 10
I would like to try with Savitsky, but I have a little problem. I donīt know what Savisky said!
Old 01-30-2006, 09:18 PM
I think what Chocomono is looking for is a copy of savitsky's method.
I'd post one but I don't have it handy - or in electronic format either...
Will
www.imaginocean.net
Old 01-31-2006, 12:16 AM
Rep: 10 Posts: 10
Youīre right.
I want to know how is the method or what Savitsky said. What I have to suppose and how can I get the power prediction.
Thanks
Old 01-31-2006, 08:27 PM
wdnboatbuilder's Avatar
wdnboatbuilder wdnboatbuilder is offline
Rep: 15 Posts: 227
http://www.sname.org/newsletter/Savitskyreport.pdf#search='Daniel%20Savitsky'
Try this link or what was suppose to be a link, anyway good luck.
Calm days, Tides Running, and Fish Biting
What more could you ask for?
Bruce
Old 02-01-2006, 02:55 AM
Rep: 10 Posts: 10
Thank you very much!
Savitskyīs method is not explained in this article but itīs interesting and I think it will be very helpful for my homework. Thank you again
Anyone can attach the method?
Savitsky Power Prediction guest12020101217 Software 131 11-04-2011 03:38 PM
Help with Savitsky Prediction and shaft inclination fede Boat Design 4 06-08-2005 08:08 PM
Savitsky correction for waterjets? nemo Boat Design 10 05-02-2005 09:00 PM
Catamaran resistance/power prediction Spiff24 Software 2 02-16-2005 12:46 PM
Performance prediction ? fcfc Boat Design 1 10-29-2004 10:09 AM
