Old 02-01-2006, 03:20 AM
BOATMIK's Avatar
BOATMIK BOATMIK is offline
Deeply flawed human being
Rep: 190 Posts: 273
Originally Posted by Willallison
Ah - ok - this is a 'school' question - thats different. You must go look at as many similar boats as possible and note down as much info about them as possible - displacement, deadrise, CG etc etc. Many things you wont be able to get info on - like CG for instance, so you will have to make an educated guess about its position
If it is a school question and they have only given length then they can't be expecting an accurate answer.
However it does open the opportunity for the student to look at savitsky and to make a presentation about what other information is needed and discuss why his/her particular educated guess for each factor (deadrise CG etc) is reasonable. Then use all the reasonable values to come up with a figure.
Then state something like ... the more accurate the inputs the more accurate the outputs, so if more information comes available it can be used for a more accurate projection.
That would be a reasonable response to the question and would show an intelligent response to a question with clearly too little data.
Michael Storer
my boat pages
Old 02-02-2006, 06:27 AM
pacoblasco pacoblasco is offline
Naval Architect
Rep: 10 Posts: 10
If you are in a Spanish naval architect University (UPM-ETSIN or UPCT-ETSINO) they have Hullspeed (maxsurf range) with Savitsky method
Old 02-02-2006, 07:41 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Chocomono:
Have a look at these interesting pages:
http://www.jbmarine.biz/Web/JBReviews.html
At: http://www.well.com/user/pk/SPApower.html you'll find a downloadable program that uses Savitky's method (Surface piercing propellers).
At: http://www.hawaii-marine.com/templat...escription.htm you can buy for 50USD an Excel spreadsheet working with Savitsky's equations.
Also an spreadsheet within these forums:
http://boatdesign.net/forums/showthr...?t=2187&page=4
Paco Blasco, is it you?
Guillermo Gefaell
Moon Yacht Design
Old 02-02-2006, 07:50 PM
Naval Architect
Rep: 10 Posts: 10
Guillermo
Yes it's me.
Nice to see you here in this other forum.
See you
Old 02-05-2006, 01:46 PM
Guillermo's Avatar
Ingeniero Naval
Paco,
World is small.
Have you tried the AINE's Forum? I've discovered it only yesterday (!!) Needs a lot of improvements, but it is a first tool....
Guillermo Gefaell
Moon Yacht Design
Old 02-13-2006, 01:18 PM
akuamare akuamare is offline
Rep: 10 Posts: 4
Allo,
I was looking for the Savitsky's power prediction method to use it in a patrol of 40m in length and..... i think this is my good luck day !!!
My more sincere thanks
PS, Sometimes we think what we do is like a drop of water in the sea, but the sea won't be the SEA without that drop
Old 02-14-2006, 06:53 AM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
Get the paper by Blount and Fox (1976 or so) that was published in Marine Technology. You can order it from SNAME.
Savitsky Power Prediction guest12020101217 Software 131 11-04-2011 03:38 PM
Help with Savitsky Prediction and shaft inclination fede Boat Design 4 06-08-2005 08:08 PM
Savitsky correction for waterjets? nemo Boat Design 10 05-02-2005 09:00 PM
Catamaran resistance/power prediction Spiff24 Software 2 02-16-2005 12:46 PM
Performance prediction ? fcfc Boat Design 1 10-29-2004 10:09 AM
