  #46
Old 11-28-2010, 06:10 AM
savagescout savagescout is offline
Rep: 10 Posts: 33
Yeah he mentioned the difficulties of getting the stepped pod dimensions correct in relation to the engine height as a step will change the way the boat performs. His thought was that he had seen many of these boats converted with a stepped pod and a full extension pod and the extension pod was always the safer bet in relation to performance.
In response to your advice above, i am actually planning to basically extend the hull much like the conversion found here http://www.classicmako.com/forum/top...archTerms=mako
Essentially the existing transom will become entirely redundant and will be cut out with the stringer/floor structure extended into the new pod/extension. This extension will be a perfect area for batteries/oil reservoirs etc and will allow for a totally different rear combing set-up, transom door etc.
Lots of planning first before getting stuck in. this is the most important stuff!
Outboard Bracket jrgrady Fiberglass and Composite Boat Building 0 12-22-2007 08:50 PM
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 03:54 AM
Outboard Bracket on 22 walk Cush8181 Powerboats 0 06-08-2004 04:07 PM
Outboard Bracket Help JOHN P. Powerboats 9 04-22-2004 07:24 AM
outboard bracket Boatbuilding 1 03-07-2004 07:35 AM
