Old 05-29-2009, 06:11 AM
Avion Avion is offline
Rep: 10 Posts: 5
Help-lost the designer...
Ages ago i found this boat on the net and saved the picture but now can't remember who was it designed by. I think it's called 'Simplicity' and it was built with plywood. Thanks.
Old 05-29-2009, 03:02 PM
Rep: 696 Posts: 1,232
I do not recognize the exact design but the hull looks like somethin the Atkins might have done. The sail plan does not look at all like Atkin stuff, nor does the ply construction. So probably not one of theirs. OK so that is probably what it is not. Very little help there eh? If PAR gloms onto this thread, it is likely that he will know better than most of us. We also have several other authorities that know many old designs. Sit tight, someone will come through for you.
Old 05-29-2009, 03:03 PM
Old 06-02-2009, 05:36 AM
Rep: 10 Posts: 5
Still hoping somebody will recognize this design...
Old 06-02-2009, 07:07 AM
Rep: 700 Posts: 3,208
http://www.atkinboatplans.com/
If you can figure the LOA from the plan , you may find her, IF she is an Atkin.
FF
Old 06-02-2009, 01:06 PM
amolitor amolitor is offline
Rep: 17 Posts: 87
I think it's around 40 feet long, and I don't think it's an Atkins. Atkins drawings tend to be different in a couple of ways, and the fully battened super-roachy sails are uncharacteristic.
Old 06-02-2009, 01:31 PM
rasorinc rasorinc is online now
Rep: 682 Posts: 1,130
it looks similar to this in my eyes. http://www.glen-l.com/designs/sailboat2/gl36.html
Old 06-02-2009, 08:24 PM
rogerb rogerb is offline
Rep: 10 Posts: 2
My guess is that it's a Sam Crocker design, as it looks quite similar to his Stone Horse designs (but quite a bit larger)
http://www.woodenboat.com/forum/show....php?p=2208775
Old 06-03-2009, 03:10 AM
Rep: 10 Posts: 5
Thank you gents for your suggestions but it's neither of those designs. From memory it's a modern day designer and he does have a quite a number of his designs listed on the web site which makes it even more puzzling to me that i can not find it again.
Old 06-03-2009, 11:10 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,639
Designer's name is Mark Smaalders......see the drawing here http://smaalders.net/yacht_design/drawingboard.htm
It's actually called the Simplicity 43'. The boat is very fine aft, which is partially dictated by the construction material. But a very fine stern coupled with shallow draft means she will be tender under a moderately large rig. Carbon spars would help, along with a heavily ballasted centerboard. Simplicity can sometimes get complex......
lost in power ??? nautical Diesel Engines 3 05-01-2007 04:16 PM
Lost Launch swcroll Powerboats 0 09-06-2006 03:18 PM
i am lost in this industry whizzyrob Boat Design 2 08-10-2006 09:52 AM
Lost Texas Boater Wooden Boat Building and Restoration 3 06-20-2006 09:57 AM
Lost Boat Designer ? VKRUE Boat Design 7 03-10-2006 02:09 PM
