Old 08-01-2005, 02:42 PM
fede fede is offline
Rep: 34 Posts: 281
HELP with ISO scantling
Hi guys, I need a clarification on a couple of dimensions regarding the ISO standard.
I’m working on the scantlings of a 9 mt (30 ft) powerboat.
When talking of bulkheads (watertight) or transverse stiffners taking place of non watertight structural bulkheads, what are exactly the “l” and “s” dimensions?
“l” is also reffered to as “lu” unsupported lenght of stiffner.
The sections I’m referring to are 9.1.1 and 9.1.2 and 7.2.1 and 7.2.2 (section 9 deals with modulus and second moment of area,section 7.2 describes stiffners dimensions) .
Attached a jpeg with a sketch of the hull and bulkheads of the boat I’m working on,longitudinal stiffners included in the upper section,please if possible sketch “l” and “s” dimensions regarding the Bulkhead on my drawing to make it idiot proof.
Please help since I’m stuck!
Old 08-02-2005, 10:01 PM
Cian Groves Cian Groves is offline
Registered
Rep: 10 Posts: 31
Hi Fede,
In the preliminary copy of the ISO standards you can find definition of 's', 'l' & 'lu' in section 7 figures 10 & 13. Basically 's' being spacing between frames, 'l' being largest unsupported length of panel & 'lu' being length of frame.
Hope that helps,
Cian
Old 08-03-2005, 03:38 AM
Rep: 34 Posts: 281
Hi Cian,thanks a lot, "s" is clear,l is clear, Lu is not so clear,with lenght of bulkhead what measure do I have to take? the height of the bulkhead keel to centre of deck? if you could sketch it on my jpeg (paint would be more than enough!) it will be great!
Thanks again!
Old 08-03-2005, 04:40 AM
Rep: 34 Posts: 281
Ok..."s" and "l" was clear, since I met the 2 formulas for minimum section modulus and minimum required second moment of inertia...a "b" measurment now appears.
My bulkhead will be made of sandwich, so I will have to check against these two formulas,in the case of a bulkhead, what are "l" and "b" ????
Height and beam (not necessarily in this order...) ????
In this case the panel under consideration is the bulkhead itself?
Old 08-03-2005, 05:08 PM
Registered
Rep: 10 Posts: 31
Hi Fede,
In regards to 'l' & 'b' for your bulkhead they will be used to calculated the plating thickness, have a look at Figure 9 & 10a. 'l' being the large dimension of panel between 2 closet stiffeners & 'b' being short dimension of panel between 2 closet stiffeners. In regards to 's' & 'lu' for your bulkhead they will be used to calculated the stiffeners size.
Hope this helps.
Cian
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 01-01-2006 12:40 AM
ISO 470xx Danielsan Boat Design 14 12-28-2005 01:35 AM
design scantling rules guest123 Boat Design 1 12-03-2004 10:06 PM
ISO 47.080 Educate me pls ErikG Boat Design 0 06-18-2003 04:47 PM
Transom Scantling Baz Boatbuilding 4 01-26-2003 06:14 PM
