were can i find the weight of aluminum tubing? |
| I went for 8ft because that is the standard length of foam sheets. May as well go as long as you can as it will reduce wave drag and there will be a good amount of both viscous and wave drag. Aluminium has a density of 2700kg/Cu.m, 40mm tube 3mm thick weighs 0.94kg/m. This around what you will need at a miniumum. Rick W. |
so only 3 sheets insted of 6 cool new card board model to come |
| 2nd model http://imgcash2.imageshack.us/Himg17...=640&ysize=480 http://imgcash4.imageshack.us/Himg17...=640&ysize=480 http://imgcash3.imageshack.us/Himg17...=640&ysize=480 http://imgcash4.imageshack.us/Himg17...=640&ysize=480 displacment with hulls all the way in the water and 4 in thick #1 160.83 gallons #2 109.72 gallons |
| what if you made the bow hull 8 feet long insted of the 6 feet long that would stop the frount from going down as much |
| I am not making anything. You need to decide the design parameters. I thought 17kts would be reasonable. If you want to go faster than this then there are better configurations. Rick W. |
| Knox I believe you have a workable concept. The next logical step would be to set out what you want to do with this boat. Things like its intended purpose, the estimated displacement, target speed, target weight, budget cost etc. Once you have this you can build a scale model to better appreciate the construction challenges and observe sailing performance. Rick W. |
| Would this work? | altura | Boat Design | 13 | 11-09-2007 07:26 PM |
| Will this work? | millrtim247 | Boat Design | 25 | 02-24-2006 10:00 PM |
| Will this work? | usa2 | Sailboats | 17 | 12-02-2005 04:35 PM |
| interior design work experience/work wanted | schwing | Services & Employment | 1 | 01-18-2005 11:52 PM |
| Will this work? | gtcway | Fiberglass and Composite Boat Building | 0 | 12-12-2004 08:48 PM |
