Old 04-26-2010, 01:08 PM
Darkranger85 Darkranger85 is offline
Rep: 15 Posts: 25
Help with first project
Hello all,
I hope this is the right place for this post, if not I apologize.
First of all let me introduce myself. I am 25 and I live in Vermont. Over the last couple weeks I have gotten very interested in building a boat.
So me and my father are going to build a very simple kayak to get our "feet wet" so to speak.
Now, I found a design that is simple and cheap. But I was hoping someone here would be able to give me additional information.
Link: http://koti.kapsi.fi/hvartial/oss3/oss3.htm
Most of the instructions are fairly easy to understand but toward the end he says that he treated it with linseed oil and dosn't explain how or why to do it.
Then he says that he applied a dark brown water repellent. Again, I have no idea how he did it. Do you need multiple coats? is there a specific way to do it? etc etc.
Is there a finish I can put on it that will make it more waterproof as well as giving it a nice glossy shine and feel?
Is there are way to increase it's Weight Displacement? (The plans say it has 230lbs currently.)
Also, on top of his instructions, does anyone here have additional advice?
Thank you all ahead of time for any help you can offer! :-)
Old 04-26-2010, 03:56 PM
Rep: 15 Posts: 25
Also, he doesnt mention if the cuts are beveled at all.
Old 04-26-2010, 06:02 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Welcome aboard the forum
Sounds like a good way to start....
Bare plywood will deteriorate over time- water plus sunlight and it'll start to check and turn grey. Linseed oil (just brushed on, let the wood absorb what it will) is one way to keep it looking OK for a couple of years. A much more durable solution is a thin layer of fibreglass cloth and epoxy.
Increasing displacement means a bigger boat. That particular project appears to be mainly a "Can we do this with one sheet of plywood" thing- neat and clever, but not a load carrier and not for rough conditions. By all means, go for it if you want- but do use some common sense, and don't load it up with 300 lb of crew and gear. If you need a bigger boat, find plans for a bigger boat and be prepared to pay more for materials.
The cuts probably aren't bevelled. It looks like the seams are just glued and filled. If you want the boat to last, taped seams (fibreglass/epoxy) would be better.
Old 04-26-2010, 06:48 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
It looks like a hair's breadth from swamping the thing in the "heeled" photo. Better be ready for a wet butt. Not really something I would take off in.
Still, an interesting boat.
Hoyt
Old 04-26-2010, 07:50 PM
Rep: 15 Posts: 25
Do you guys have anysuggestions if you think this one isn't quite what it should be?
My main things are:
cost - has to be relativly cheap to build.
Simple- this is a two fold point. One being that we have no experience so simple is good and the other being that I don't want it to be something that takes months to make, I am hoping to be able to get out on the lake this year. . Preferably not the end of the year.
Thank you guys for your input so far!
Old 04-26-2010, 10:43 PM
Rep: 749 Posts: 1,314
The dugout thing is a clever use of a single piece of ply. That is well and good but it does not make much of a boat. In fact it a a weird looking contraption that is very apt to send you swimming. The long overhangs on the ends are absurd. The plans are cheap enough but the result will not be worth the time and money you have spent.
If you want a low cost, simple to build, quick to build, entirely adequate, double paddle boat, I urge you to take a look at the "Six Hour Canoe" There is a paperbound book that you can buy (same name: Six Hour Canoe). The book will give you every building and finishing instruction you need. A lot of these boats have been built, and used successfully.The name is misleading in that a person who has never built a boat will probably need twelve hours to build this one. You can build the boat in a few days by working on it a couple of hours at a time. The real time consuming part comes after the boat is built. Now you have to finish it. That means that you will need to spend some time sanding and painting. There goes another ten to fifteen hours depending on how pretty you want it to be. Try googling; Six Hour Canoe. Please do yourself a favor and forget the dugout type weirdo travesty that you referred to.
Old 04-27-2010, 02:53 PM
dreamer's Avatar
dreamer dreamer is offline
Soņadora
Rep: 188 Posts: 307
I can tell you something about this. Not the boat, but about the fact that it's from a Finn.
I married a Finn.
This is a drinking boat.
i.e., you build it, put it in the yard, grab some vodka, sit in it and drink.
Don't let those pictures of it actually floating fool you.
Rick Beddoe
s/v Soņadora, 1978 Baba 30
Senior Designer, Sons Creative
"Study nature, love nature, stay close to nature. It will never fail you" - Frank Lloyd Wright
Old 04-27-2010, 03:20 PM
Rep: 15 Posts: 25
Again, thank you guys for the information.
I have purchased the Six Hour Canoe book and can't wait to read it.
In the mean time I have been looking at other things as well and was wondering if you guys would have some input on the "seaworthyness" of this kayak plan.
They are from www.Jemwatercraft.com and are free plans.
Old 04-27-2010, 04:25 PM
hoytedow's Avatar
Resistor
Much better than your first submission.
Hoyt
Old 04-27-2010, 06:46 PM
Rep: 15 Posts: 25
I'm glad to hear that. :-)
How about how difficult would it be to build for a novice?
Old 04-27-2010, 06:51 PM
hoytedow's Avatar
Resistor
That depends on how smart you are. If you are generally skillful at problem solving it should be fairly easy for you. Take your time. Measure twice before each cut. Make sure you only cut what you intend to cut. Don't use any product without gaining knowledge first. Keep a first aid kit handy.
Common sense. Then you won't need the first aid kit.
Hoyt
Old 04-27-2010, 07:43 PM
Rep: 15 Posts: 25
The only problem with them is I don't see a bill of materials anywhere in the plan.
Old 04-27-2010, 07:45 PM
hoytedow's Avatar
Resistor
Keep looking. I am sure it is in there somewhere.
Hoyt
Old 04-27-2010, 07:46 PM
hoytedow's Avatar
Resistor
Keep all receipts for materials if you want to get a title for it.
Hoyt
Project management templates for MS Project expedition Boatbuilding 2 08-14-2009 05:46 PM
Project management templates for MS Project expedition Software 0 08-14-2009 04:35 PM
New project. help please..... boatrehab Boatbuilding 12 07-11-2007 09:42 PM
My new project glockrow Wooden Boat Building and Restoration 17 06-19-2007 08:50 PM
project donjames Option One 0 09-19-2004 01:50 PM
