Old 09-28-2007, 03:15 AM
SD spero SD spero is offline
Rep: 10 Posts: 2
help with fiberglass
Just picked up a used hull. it has a spot at the bottom of the bow were its worn through the gelcoat and a layer of glass (i would guess from nosing up on the sand) do any of you have a suggestion for a process to fix it. I have some skill with glass work.
Old 09-28-2007, 07:45 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
There's some good video's on Youtube.com just search on "fiberglass repair" also the west system site has lots of info http://www.westsystem.com/ just look under the projects tab on their web site.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 09-28-2007, 08:46 AM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
There are also bow protecters that glue on or stick on somehow. Google "keelguards" and go from there. Maybe you won't have to repair anything.
Old 09-28-2007, 10:01 PM
Rep: 10 Posts: 2
thanks , I have seen the videos and have done a fair amount of glass work. the problem is the damage is right on the cutting edge of the bow. do you think a low density filler will hold up?
"The mode with which the impossible happens is effort." Jack Hachigian
Old 09-28-2007, 11:23 PM
Geoh Geoh is offline
Rep: 12 Posts: 53
Same prob only my hull 13' Galaxie jet boat has the scraped problem the whole length of the keel...thinking maybe a 6" wide fbr gls the whole length....no fbrgls skills here but got the hull for nothing and want to learn on it...
not a jet guy...but might be fun to run up and dn on the colorado river between laughlin and havasu
George
Old 09-29-2007, 12:12 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
Prep by cleaning with acetone and then sanding to roughen. Mask off areas surrounding.
Best to fill the damage with a bit of epoxy mixed with filler. West 105 resin with 206 hardener and microballoons as filler. Mix til it will fluff like cake frosting without sagging.
Epoxy is applied to the area. A thick clear polyethelene patch can be used to assist shaping by being laid over the wet epoxy and then manipulated with a wide putty knife. This allows the epoxy to be shaped into a near perfect replica of the ground-off material. All excess epoxy is drawn out the sides of the plastic patch and cleaned away. After curing, the plastic and the masking is removed. Match with gelcoat or paint, but do cover to keep the epoxy from UV degradation.
Alan
Old 09-29-2007, 01:41 PM
FranklinRatliff FranklinRatliff is offline
Rep: 84 Posts: 294
Repair
Alan
Do what Alan says.
Old 09-29-2007, 03:37 PM
Rep: 12 Posts: 53
Thanks Alan
I was afraid i needed the fabric strip. Saves me a lot of unnecessary work.
George
Old 09-29-2007, 05:35 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
I agree with Alan, for the most part. Thickened epoxy is the way to go. You want it at about a peanut-butter consistency by the time you're done adding the filler powder.
What to use for the filler powder is another question. Microballoons have been suggested. This option is probably the easiest to work with. But do you intend to be running the boat up on the beach, as the previous owner did? If so, you might want to consider a stronger filler, like a colloidal silica, since the microballoon/epoxy mix will wear down fairly quickly (it's designed to be an easy-to-sand mix, after all).
Wax paper works quite well as a covering, too, to get a smooth finish if you don't have the thick, clear polyethylene Alan mentions. Believe me, the extra work to do a really good job with the smooth clear covering sheet is worth it, because the epoxy's awfully strong if you have to sand it smooth afterwards.
Old 09-29-2007, 07:08 PM
alan white's Avatar
I want to add that covering and smoothing with plastic sheeting is not a viable method with surfaces that are rounded a lot on two axes (strong compound curvature). Such might be the case here, judging by the stated cause of the damage, likely the knuckle, or transition between stem and keel.
in such a case, one solution is to layer glass mat over the prepared surface, until it's sure the layering is above the finished surface desired. Mat is good for resisting gouging next time. It will have to be dressed and recoated (I suggest a coarse "flap disc" (radial over-lapping flaps on the FACE, not the edge) that you can get at Home Depot, though any normal sanding disc would also work.
After careful shaping, add epoxy/microballoons as a sandable fairing compound (this time not like icing but more peanut-buttery for strength). This coating is mostly epoxy, and thin enough to be more cosmetic than anything else. The real beef is in the mat underneath. Sand, wet sand, paint or gelcoat.
A.
Fiberglass fire damage to a fiberglass boat Eagle Boats Fiberglass and Composite Boat Building 26 11-14-2011 12:17 PM
fiberglass equipments needs Guest-3-21-09-10-33 Marketplace 5 01-17-2007 12:25 AM
Fiberglass help timplett Boatbuilding 7 09-19-2006 06:11 PM
Fiberglass Help d522250 Fiberglass and Composite Boat Building 4 05-26-2006 08:36 PM
fiberglass help MF11283 Fiberglass and Composite Boat Building 9 09-25-2005 02:53 PM
