| Help with a Delcraft alum boat I bought what I believe is a very old "Delcraft" aluminum boat. Googled them: nothing there.The label with the model: #14-167 (etched by hand- not machine stamped- so it's hard to tell for sure- that's my best guest), the serial #: 7754, and the max. rec.: h.p.: 14. Label states the boat is "A product of Delhi Manufacturing Corp. Delhi, Louisiana. (1.) Anyone know for sure when they stopped making 14 hp motors? That would probably be a start at knowing how old it is. (2.) It's in great shape: no beer can thin aluminum in this baby, but the wood on the transom must be replaced. My question is this: there is a brace that is riveted to the bottom of the boat and runs diagonally to the transom and is riveted through the wood and the alum. Can I drill out the rivets, replace the rotten wood with marine plywood (looks like 3/4 inch) and then reattach the brace with stainless steel screws, washers, and bolts. I have a drill and a saw but I don't have a rivet gun. Ideas appreciated: this will be my first ever boat project. Also, this is my first time posting. If I posted this in the wrong spot I'm sorry. Looked like the best fit. Thanks, Angelfish |
| Delcraft Alum Boat I have a 14 ft. Delcraft Alum boat also. My mom and I bought it for my dad's birthday in 1962. The model is the same as yours and the serial # is 74**. (sorry I don't give exact serial numbers on forums). About the transom, we replaced ours 3 years ago and we went to a boat shop and bought 1 inch thick plywood then had someone to fiberglass it to seal it. And the brace in the bottom? we just drilled out the rivets and replaced with stainless steel bolts with clear silicon around them. It leaks a little but it is not enough to get our feet wet after being on the water all day and night. I wonder what ever happened to Delhi Manufacturing Corp. Delhi, Louisiana? I tried to google them also and nothing there. You are the only other person I know that has a Delcraft Alum boat. Please let me know if you received this post because this is an old post and the forum gave me a warning at the bottom. ![]() |
| I have a 12ft Delcraft which I will use a 1946/49 Johnson to power it by. I'm trying to locate the serial number but I cannot locate it. Does anyone know where this number is usually located. I have looked all over the transon both inside and out, no luck. Thanks, Don |
| First time alum boat builder with lots of questions. | Bob boat bldr | Metal Boat Building | 5 | 11-14-2006 09:28 AM |
| Prop Material - Alum boat | sal's Dad | Metal Boat Building | 9 | 07-13-2006 02:24 AM |
| Any classic "V" alum designs? I have the boat, want to finish it. | cpholley | Boat Design | 2 | 05-09-2005 02:47 PM |
| Looking For Small Fishing Boat Plans Alum. | PDH | Boat Design | 3 | 03-21-2005 07:56 PM |
| delcraft boats | bammy the bass | Boatbuilding | 0 | 09-28-2004 03:35 PM |
