Old 06-24-2006, 11:11 PM
75HUSTLER 75HUSTLER is offline
Rep: 10 Posts: 6
help/carpet glue
i starting to restore my 75 hustler jet boat. I got it gutted but cant get the carpet peeled from the floor and strigers. any help will help. thanks.
Old 06-24-2006, 11:52 PM
Rep: 593 Posts: 2,054
Heat Gun
Have you tried an industrial quality heat gun? Available at Home depot, etc. These dudes are very hot, so go slowly and raise the temperature of the adhesive without setting the boat or carpet on fire.
Once you get a corner up from the hull surface, you can direct the airflow onto the adhesive itself and then it starts to come off quite quickly. Wear gloves to prevent getting a burn and watch where you set the gun when changing positions.
Absolutely not around fuel lines, fuel tanks or anything that is highly combustible in nature.
Second idea would be a squirt bottle of lacquer thinner which will dissolve the adhesive enough to get the carpet off the hull.
In both cases, you'll have a nice amount of glue residue left behind.
Not a fun job.
Chris
Glue for lapstrake FrankThomas Wooden Boat Building and Restoration 6 01-13-2006 08:32 AM
Gorilla Glue softreq Materials 11 08-22-2005 04:37 PM
Stich and Glue Phosphor Wooden Boat Building and Restoration 12 04-26-2004 08:04 AM
What glue jesseh Boatbuilding 3 09-21-2003 02:08 PM
stitch and glue Boatbuilding 2 06-27-2002 09:33 PM
