| You may be pushing the S*** stuff up-hill with a pointy stick as the data Frosty found the vessel was only 1000t and the replacement (via my post 2700t) and it had a WASP helio... http://en.wikipedia.org/wiki/Westland_Wasp Data from Westland Aircraft since 1915 [14] General characteristics * Crew: One pilot, one Aircrewman * Capacity: up to four passengers * Length: inc rotor 40 ft 4 in (12.30 m [15]) * Rotor diameter: 32 ft 3 in (9.83 m) * Height: 8 ft 11 in (2.72 m) * Disc area: 816.9 ft² (75.9 m²) * Empty weight: 3,452 lb (1,569 kg) * Max takeoff weight: 5,500 lb (2,500 kg) * Powerplant: 1 × Rolls-Royce Nimbus 103 turboshaft, 1,050 shp [16] (783 kW) Performance * Maximum speed: 120 mph (104 knots, 193 km/h) * Cruise speed: 110 mph (96 knots, 177 km/h) * Range: 303 miles (263 NM, 488 km) * Service ceiling: 12,200 ft (3,720 m) * Rate of climb: 1,440 ft/min (7.3 m/s) * Disc loading: 6.75 lb/ft² (33 kg/m²) * Power/mass: 0.19 hp/lb (0.31 kW/kg) Ambition and reasonable possibility seem to be getting further and further apart...
__________________ Try to be helpful... Remember that there are at least two sides for every story... |
| http://en.wikipedia.org/wiki/Airwolf_%28helicopter%29 Airwolf vs. Bell 222 Bell 222 Airwolf Crew 2 (pilot & copilot) 2–3 (pilot(s) & weapons technician) Passengers 5–6 1–2 (non-crew may use the copilot seat and/or a seat behind the technician's seat) Length 49.54 ft (15.10 m) Height 11.68 ft (3.56 m) Weight 4,555 lb (2,066 kg) unspecified Speed 149 mph (240 km/h) 345 mph (555 km/h) conventional, Mach 1+ with turbo thrusters Range 373 mi (600 km) 950–1,450 mi (1,530–2,330 km) Ceiling 12,800 ft (3,900 m) 11,000 ft (3,400 m) unpressurized 100,000 ft (30,000 m) pressurized Power (×2) 618 hp (461 kW) unspecified
| I cannot comment regarding the possibility of the installation of the helipad. I am new with all of these and just learning bits and pieces form your posts. As I stated earlier in this thread, I am only complying to what the owner wants me to research about and hopefully with your insights/comments s/he will be able to make the right decision when it comes to taking the right path/options for the retrofit. Her/his goal is to maximize the retrofit and be able to include all the possible services the yacht can offer/accommodate. As the long term plan for the yacht is to charter it for a few years and then sell it. |
| Thanks for the info Frosty Oh your welcome!! |
| The owner has asked you to do something and you can't work out what sex he/she is. Good luck in working out how to do a helipad. |
| Poida I never said I was any good at either. Did I mis something who asked me to do something--panic--its not on my screen --where? Sex? what sex is she then? |
| Anne, This is a fun group hu? Without more info on exactly what ship, and what helo are being married it is a bit of a stretch to give any specific details. But it appears the owner is trying to squeeze more aircraft on the boat than it can reasonably hold. The difference between a small 2sob aircraft and a 6 sob is huge.
| Frosty My post #20 is in relation to post #18 |
| HMS BULLDOG - Yacht conversion _ Helicopters Dear Anne, I am a former Royal Navy Officer and a former Commanding Officer of HMS BULLDOG - the yacht conversion I believe you are involved in. With suitable modifications I believe BULLDOG is more than capable of a land on capability for a Westland Wasp sized aircraft. The BULLDOG class were tough with excellent seakeeping capability. I have operated Westland Wasp (from the stern) and Seaking ( from the bow) in VERTREP mode. The Seaking was a bit to big, but a Wasp sized aircraft on a flight deck over the stern would be achievable in my opinion. If you have any photos of BULLDOG in her new role I would be very grateful for them, including any other information you can supply. Best regards, Andrew. |
| retrofit jet drive | autobahnbuyer | Jet Drives | 3 | 03-08-2010 11:11 PM |
| Helipad material | 902twin | Boatbuilding | 6 | 06-07-2007 04:48 PM |
| yatch design schools??? | samsingh17 | Boat Design | 5 | 05-24-2007 02:52 PM |
| Retrofit turbine engine to powerboat. | Verytricky | Propulsion | 21 | 02-24-2006 01:54 PM |
