| Heel Drag ratio? Hi I have an exam in two weeks and need a bit of help regarding Sailing Side Force and heel drag ratios, and would really appreciate some info. What I though was the heel drag ratio was the ratio of the drag when the model is heeled to that when it is upright, is this correct? I am given a table of tank test data of, Side Force and Drag at 0 degrees Heel and 0 leeway and then 3 readings at 20 degrees heel on both tacks with different leeways (0,2,3 degrees) and need to get the heel drag ratio, is my method correct? Thanks a million! |
| Need help, Sailing side force & heel drag ratio! | GuestR01312011 | Sailboats | 2 | 01-12-2008 03:34 PM |
| 1:78 ratio vs. 1.47:1 ratio ... which to choose? | ezfriday | Propulsion | 18 | 02-18-2006 09:21 PM |
| Vpp heel resistance | idkfa | Boat Design | 2 | 09-20-2005 05:54 AM |
| It is good to stop of heel? | Ivanmdq | Sailboats | 1 | 05-05-2002 05:19 AM |
| No heel!!! is reality? | Ivanmdq | Sailboats | 0 | 02-17-2002 04:48 PM |
