| Have older fiberglass kayak paddle that 'sheds' It sheds glass from the shaft, although the shaft is 'all there' and in perfect condition. It has a visible cloth pattern showing through, in cool colors. Looks neat, but not a good idea IMO. I'd rather paint the whole shaft rather than tape the hand holds, as it sheds from the other parts as well. It is annoying. I just want to paint it, or something, to prevent the itch. Any tips or REASONABLE recommedations on the type of paint. I only use it occasionally, and don't want to get into a full blown 'gel coat' project. Will any decent enamel spray paint be OK. I do use it in salt water. |
| Hi, I don't know what "sheds" means (becouse I'm not english speaking), but I guess that the glassfibre is starting to stick "out"? Then you should just paint it with epoxy (or polyester if its made of that). HOW old is it? If you use some sand paper on it, it will smell polyester at once, but if odorless, it will be epoxy. You have to use the same type as its made of, unless it will not stick good to it. You have to sand it anyway to have anything stick to it! If using pure epoxy or polyester, the paint will shine trough! ![]() |
| Paint will be a very temporary fix unless you wrap it with something. Just cloth will do, you need to sand it real good first. Get some Dacron cut three or four inches wide and wrap it neatly. You can use any water proof glue to fix the ends until the paint drys. I would not use spray paint, it has no body. Get some oil base, even spar varnish will work. Main thing, it needs to be clean and rough to make it last. Glass and epoxy will be best, but you still need to paint it, UV you know. |
| How about some very light fibreglass cloth covering - and a layer of epoxy. That will be the only thing that would stop the decay. |
| Helloooo! Anyone listen to me? As I said: epoxy or polyester is the question! you cannot use epoxy on polyester vice versia. "smell" it first to find out what it is! (Polyester will smell alot, but epoxy notthing) Then rub it down with sand (need to rub it down anyway). Then simply add polester or epoxy as a "paint". |
Squidly, just sand it down first to get rid of the loose fibers on the surface and to remove any of the original resin on the surface that's apparently damaged and causing this problem in the first place. Then wrap a thin fabric of some kind around the shaft (doesn't have to be glass), coat it with epoxy, fill the weave, sand it smooth, paint it, and start using it again.
__________________ Kenneth Grome |
| I'll second that, epoxy is the only way to go.
__________________ Wake me up if we hit something. And you guys can Call me Joe |
| Thanks everyone, I'll look into epoxy. I've heard other 'fiberglass gurus' say only epoxy is worth your time on any repair. The shaft is 'all there', it just imparts a fiberglass itch when it rests on non-calloused skin. |
| If you can lean on one of your gurus- just sand it down with some 220 and have them spay a coat or two of Awlgrip 545 primer. It's an epoxy paint but will last sort of forever out it the sun and is dead easy to apply, will look good and seal up the surface. If you start glassing up the surface or using pure epoxies the sun will eat it up over time and the whole fairing issue is a PITA. You can spray it yourself using one of the disposable prevalve units but then you have to buy the 545 and the whole deal gets too expensive fast. Fast and dirty which will last for a good long time- Rustoleum spray paint from your local hardware store. |
| Rustoleum sounds best, next season I can buy another can. I'm still wondering 'what is up' with this 'shedding'. I've never seen(felt) fiberglass that has been wetted start giving up fibers. The paddle was obviously professionally made, and pretty expensive at the time. Maybe it was done on the bleeding edge of 'lightweight' as far as resin/cloth. |
| Squidly Why not stop by the hardware store and get a roll of common friction tape and give it a good wrap, replace it every couple of years. Might cost $2.00? Take 10 minutes? |
| its old and detereorating its called whitining like a delam it needs a new wrap and gel kote finish |
| Sun has just burned up a bit of the resin in the outermost layer so the fibers are exposed. Very common in bits that see lots of sun like vhf antennas, spring poles, etc. Used to work on a old houseboat that has the whole house structure shedding like this- was a real pita. I have a carbon kayak paddle in the same shape- I will spray it one of these days if I ever remember to have it around when I have a spray job going. Rustoleum will buy you years of service- really a pretty decent paint. Regards |
| resin and epoxy have same bond ...bond is only as good as your scuffed area is roughed up ..i mix resin with bondo thined with acetone as a epoxy everyday |
| Do they exist? articulating paddle wheel | justinDesign | Propulsion | 27 | 02-01-2009 09:31 PM |
| Can I put fiberglass over a canvas kayak? | green1181 | Fiberglass and Composite Boat Building | 8 | 04-26-2008 08:53 PM |
| Anyone have articulation paddle wheel info | justinDesign | Boat Design | 19 | 10-04-2007 11:52 AM |
| Canoe Paddle question | Alixander Beck | Wooden Boat Building and Restoration | 10 | 05-24-2007 11:41 AM |
| restoring a fiberglass kayak | cnu | Fiberglass and Composite Boat Building | 5 | 04-13-2006 04:16 AM |
