Old 12-25-2011, 05:38 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
Hat Section Bulkheads? These I DO plan to install.
Have you all seen this type of bulkhead installed before?
I finally hit on the right layout for our boat and it will involve making a little more open room. They use these in aircraft and in Gunboats.
Any issues doing them?
Are they always foam filled? Very light foam, I'd imagine?
(Hat section bulkhead is located on lower left corner of the picture)
"You can't solve all of life's problems with epoxy" - My Wife
Old 12-25-2011, 05:55 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
Either hollow or wood filling if you need to have bolts or screws..
BR Teddy
Old 12-25-2011, 06:48 PM
rberrey rberrey is offline
Rep: 69 Posts: 287
Looks like you could just foam fill to me, but I doubt you would even need to fill. Rick
Old 12-25-2011, 07:01 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
What happens if you put a Thin paneled bulkhead Underload ??
What is a bulk hulk head actually there for ??
Is it structual ?
if its not serving any useful purpose why even bother making it and putting in in at all ??
Hollow ??
weak foam??
Why not just make it out of paper !!
why bother ??
Making beautiful boats is a passion never a chore !
Old 12-25-2011, 07:45 PM
Rep: 69 Posts: 287
With three sides glass you would have a basic hat channel, counting the hull skin you would have four sides making it a box beam. Either of these would be structual in nature, how strong it is depends on size and material. Rick
Old 12-25-2011, 09:04 PM
old one !
Theres a million ways to make box beams that when placed under stress wont totally collaps or twist out of shape and become next to useless .Box beams is a whole science on its own . same when making hollow stringers or foam filled stringers . the height ,width and actual size and how its made is vitally important . with shaped sides a box beam can become a semi spring to absorb shock loadings . A beam that can absorb loads like a spring and returning to its origanal shape is a whole lot of fun to play with . Solid glass hull bottoms with very few frames but use long stringers that have a dregree of bend can be made to make the boat ride much smoother than a ridged hull with lots a frames and no flex at all .
Along with flex twist is closely following . twist and flex can be made to be able to work together and make almost indistructable panels !!.Used in rescue work and life threatening situations panels can be designed in a way to progressivly distruct slowly and not simply snap and break like a carrot .
Carbon is the worst carrot of all !! there one second and then gone completely the next !!,so has no place here !
Glass on the other hand will hang on and hang on for a long time before finally saying bye bye .
Used to make surf boats that were light strong flexable and would twist .Most of the chractoristics of a soft bottom boat but the added advantages of a ridged with highter speed and beter manuoverability , and not slipping and sliding every where .
The Boat crew could have legs broken and sprained ankles with cracked ribs after riding and getting caught in really rought huge waves but the boats could land back on the beach with over a ton of water inside and never burst open or break or have any visable signs of stress or damage !
Never used any fancy resins and just 2 simple types of Glass that nearly every supplyer has heaps of on there shelves . The secret is in how you use those two types of glass !!
its not engineering its not rocket science ,Its impossibe to computerise a program for , its just plain good old common sense! and know how !!!
Most important!, understanding the capabilities of the materials you are working with !
What you can do and what you cant do !
what you should do !and what you shouldnt do !
Old 12-25-2011, 10:52 PM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 394 Posts: 508
I don't see a bulkhead in the lower left corner! What I do see is a frame.
Best regards,
Søren Flening
NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects.
Old 12-25-2011, 11:29 PM
eyschulman eyschulman is offline
Rep: 72 Posts: 160
At some point when a ring bulkhead gets cut out enough it must become a frame and if it goes all around the structure is that then a ring frame?
Old 12-26-2011, 01:47 AM
sabahcat's Avatar
sabahcat sabahcat is offline
Rep: 257 Posts: 791
BR Teddy
Bollocks.
I have seen this sort of thing done on 40 fters with white, non-structural polystyrene with a heavy uni cap and then 2 staggered layers of 800gsm biax
Old 12-26-2011, 01:54 AM
Originally Posted by sabahcat View Post
Bollocks.
I've seen them done on 66 footers the same way you mention as well. The picture above is from a Gunboat 66. One of the best offshore catamarans made. No doubt as to the seaworthiness there.
I wonder how many bulkheads can be replaced this way? Could I do 2 in a row, not including the real structural ones?
TeddyDiver's Avatar
Gollywobbler
Bollocks.
And I have seen hobos to drink denatured alcohol but wouldn't do that either
Old 12-26-2011, 02:08 AM
TeddyDiver's Avatar
Gollywobbler
Yes, all if you want to, but you have to know scantlings for these beams, becouse that's what they are structurally. Some of these members replacing bulkheads can also be fixtures working as additional beams or stringers laminated btw the beams.
The stryrene Saba mentioned can be used to shape the section in place especially if you need to make a kinky shaped one. However it doesn't have any stuctural purpose (styrene).
Old 12-26-2011, 02:22 AM
Rep: 670 Posts: 2,457
Hat section ring frames are very common. Simply get the scantlings correct.
Im watching a chainplate ring frame being retro fitted to 25 footer now. Its a two halves...port , starboard frame. Most of the actual fabrication is being done in the workshop. The frame , once finished , will then bonded into the boat.
Old 12-26-2011, 06:56 AM
old one !
You got it . We had patterns and made everything on the bench including the placement of the uni layers the ran round the inside and were glassed over . Had one team set up to bag and make all the frame work and deliver to the boat at the right time including the longtudinall framing as well with large cut outs on the insides .
Hat Section Bulkheads?  These I DO plan to install.-1000032660.jpg  Hat Section Bulkheads?  These I DO plan to install.-1000031816.jpg
Old 12-26-2011, 07:57 AM
Here is a link to my designer discussing the hat section, including scantlings.
http://multihullblog.com/2011/04/pro...-hat-sections/
rotate a round section or a wing section ? simonfraser.97 Boat Design 3 11-11-2009 01:44 AM
ISO top hat second moment of area apfelsaft Class Societies 10 03-27-2009 02:22 PM
front section has semi-elliptic plan and exponential profile... idkfa Multihulls 1 05-12-2008 11:35 PM
Straw hat foil cruising! Richard Hillsid Boat Design 0 06-06-2006 04:32 PM
Top Hat with Carbon or E-Glass UD's Boa Boat Design 2 06-09-2004 06:49 AM
