  #46
Old 01-03-2012, 08:59 PM
upchurchmr upchurchmr is offline
Rep: 224 Posts: 526
Cabinets are not worth squat for spreading load from a chain plate.
  #47
Old 01-03-2012, 09:16 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Chain plates are major structure and should be treated as such trying to use other things to pull on is a not brainer !. the loads need to be spread over a wide area not just a localised place . should have been built in and part of the hull structure when the glassing was being done . all mono hullis i ever made we had uni's run from one gunwhale to the other all way down the hull into the keel area and up the other side mixed in with the hull glassing not an after thought and added to after !!.they need to be stong enough to lift the boat with and never have to question there ability to do so !!
Making beautiful boats is a passion never a chore !
  #48
Old 01-04-2012, 12:14 AM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
It's pretty well settled. I noticed that one of the interior plans for the boat has a hat section at this very bulkhead to throw a couple bunk berths in for max sleeping capacity.
"You can't solve all of life's problems with epoxy" - My Wife
rotate a round section or a wing section ? simonfraser.97 Boat Design 3 11-11-2009 01:44 AM
ISO top hat second moment of area apfelsaft Class Societies 10 03-27-2009 02:22 PM
front section has semi-elliptic plan and exponential profile... idkfa Multihulls 1 05-12-2008 11:35 PM
Straw hat foil cruising! Richard Hillsid Boat Design 0 06-06-2006 04:32 PM
Top Hat with Carbon or E-Glass UD's Boa Boat Design 2 06-09-2004 06:49 AM
