| hardtop for cat hi annyone built a hardtop? i am planning to build a hardtdp to replace my biminy top. i have a 38 ft catamaran and the top will be 7 1/2 by 12 1/2. it has to be light weight and strong enough to walk on. i was planning to use 5/8 divinycell h80 foam for a core with 2 layers of1808 s glass on top and bottom. i am wondering what additional support will be required to span between the vertical supports used at four points two in front and back. if annyone has plans or has built one similar i could use the advise jt Last edited by captjohn360 : 12-05-2004 at 09:33 PM. Reason: move to boat building |
| hard top this was just a vinyl awning when i got ahold of it now it is a hard top. |
| the back view. it is made of one layer of 1808 with a layer of 1 1/2 oz chop on top of that with a 1 1/2" foam core. it is 8' wide and 12' long. |
| Hardtop | gcw | Fiberglass and Composite Boat Building | 18 | 06-24-2006 11:59 AM |
| Comments on my building methods (hardtop construction) | DNSeal | Fiberglass and Composite Boat Building | 10 | 12-16-2005 09:15 PM |
| 1972 Hardtop - Stringer and glass | campbell | Boatbuilding | 2 | 06-25-2005 12:51 AM |
| another hardtop | captjohn360 | Fiberglass and Composite Boat Building | 1 | 12-12-2004 09:16 PM |
| Hardtop Construction | cgorton | Fiberglass and Composite Boat Building | 8 | 04-25-2004 06:12 PM |
