Old 11-20-2009, 10:10 PM
Chuck Losness Chuck Losness is offline
Rep: 60 Posts: 147
hard dodger
It's time to replace my existing dodger on my Gulfstar 37. I like the existing shape. So I plan to use the existing frame to support a hard top with cloth sides and vinyl windows. After considering a bunch of different ways to make the hard top and the available materials here in Mexico I have decided to make the top out of 2 layers of 1/8" plywood covered with fiberglass cloth and epoxy, then painted. The most weight the dodger would have to support is 3 solar panels.
My question for the forum is what other types of glue besides epoxy can I use to glue the 2 layers of plywood together. I have thought of using titebond 3 and have read the thread on that glue. Would it work in my application? It has also been suggested to use contact cement or construction adhesive like liquid nails. Any other suggestions?
Any advice on clamping pressure would also be appreciated. If needed I can just screw the layers together while the glue goes off and then remove the screws before applying the fiberglass and epoxy.
Thanks for your assistance.
Chuck
SV Hale Moana
currently in Puerto Escondido, BCS, Mexico.
Materials for a hard top dodger/bimini ryanonthebeach Boat Design 3 07-27-2009 09:19 PM
how hard? fiatjeepdriver Wooden Boat Building and Restoration 5 10-03-2007 06:27 PM
Hard Dodger design & construction (ProChine) RyanN Boat Design 7 09-29-2007 01:57 AM
Hard Starting boater-rick Powerboats 4 01-15-2004 11:15 PM
The Too-hard Basket tom kane Powerboats 11 12-19-2003 08:20 PM
