| Hard chine flat bottom Hi! I am building a flat bottom boat and wondering the benifits/disadvantages and characteristics of a hard chine. The hull is 16 1/2' long, 86" wide bottom flaring at 105 degrees. The bow tapers to 5' at the 12' point from the stern. What can I expect? |
| Here is a link to a story about the flatbottom skiff that i designed and built. I have logged over 60,000nm of open ocean in this skiff since '91. http://www.oceanskiffjournal.com/Sub...tprofile1.aspx My skiff is 19ft LOA, the bottom length being 17.5ft. The bottom is 59" at the widest point, 2/3 fwd of the transom and tapers to a width of 51" at the transom. I would not recommend a 16.5' hull with a width of 86". Also, i would keep the flair to 100' to 102' max. What do you plan to use your skiff for and how do you plan to power it? Brad (loves the sea) |
| Pretty impressive Brad! This thing is not really a skiff but an airboat. Just really wondering how this thing might handle? |
| Airboats in this part of the world are typically soft chine layouts. They are very wide in comparison to length, in about the same proportion that you have suggested. Airboats are inherently top heavy and the Florida boats keep well rounded chines so that the boat will skid rather than trip. If you are planning to use a powerful engine in the quest for speed, then do give some consideration to the tripping possibility. Flare in an airboat is not necessary except for the possibility of keeping the spray down. That can be accomplished with a pair of whiskers just as well. A slab sided boat is not as pretty as one with flare but a lot easier to build. If you plan to trailer the boat 105" is too wide in many US states. Best check the Alberta regulations. Will you be powering this boat with an aircraft engine or a big automotive V8? 350 cubic inch engines are popular herabouts. Some of them use race car engines that make upwards of 500 HP. I think those guys are out of their minds but they don't pay much attention to what I think. |
| Yeah, flare is 105 degrees, width is 96" and 89" X 12' bottom. Big auto engine. Was wondering if a water rudder would reduce the trip hasard? |
| Depends if you are sailing or powering. Flat bottom sharpies like the Norwalk Island sharpies sail well heeled over, as the flat bottom and side make a V at sailing angles. Powering will be fast, but in any kind of sea, it will pound a lot. Quite jarring over 15 knots |
no as it is the chine which will dig in regardless of the rudder. A vee bottom will bank into a turn but a flat bottom doesn't bank nearly as well, and when it starts to slide...it has the ability to catch the chine and flip...very quickly. Steve |
| Yeah I'm getting pretty convinced i need to do something about it. The hull is .105" steel and I could cut out a wedge to soften it BUT I was looking at the hull and I think I will do an add on about 1" above the bend and make a nice glass rounded chine out of foam and glass. Positive flotation, extra bumpers and soft chine. Just bolt the side attachments on to the hull. Sound like an acceptable plan? ![]() |
| I found a video of an airboat with pretty much the same hull shape as mine. Doesn't look like it's tipping over so I'll leave it as is for now and if I don't like the way it handles at least i have a plan up my sleeves! http://www.southernairboat.com/photo...o/2390/cat/526 Here's another couple I kinda get a kick out of! http://www.southernairboat.com/photo...o/1810/cat/526 http://www.southernairboat.com/photo...to/413/cat/526 Thanks for the help! |
| Freeship hard chine hull help | arc alaska | Boat Design | 2 | 10-19-2006 09:26 AM |
| what about hard chine aft | jelfiser | Boat Design | 8 | 07-23-2006 09:56 PM |
| Hard Chine Definition Needed | Phosphor | Boat Design | 16 | 07-09-2004 11:11 AM |
| Chine Flat Construction Questions | spank | Boat Design | 1 | 02-16-2004 04:35 PM |
| Hard chine boat design | Guest | Boat Design | 0 | 09-10-2003 11:50 AM |
